Go to Post To have respect for the process you are in right now, respect the knowledge around you by using it to your full advantage. - Scott Ritchie [more]
Unread 17-01-2011, 15:04
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Multiple Axis Cams?
This may seem an invalid question to consider, but...
Are we allowed to use multiple Axis Cameras? I intend on using one for minibot deployment and one for the scoring of game pieces
(I am not asking this on the Q&A because only our teacher has the password, and she doesn't want to forward it to us, and we have had a week off for school because of the Snow storm that hit the south last week. )
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 18-01-2011, 08:12
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Multiple Axis Cams?
Anupum,
From the First "How To Configure Your Camera" doc...
The camera can also be connected directly to the radio and bypass the cRIO if you choose not to use image processing. To set up the camera this way, the camera IP address is based on team number and is 10.xx.yy.zz, where zz is in the range of 11 to 20. The xx.yy is the same as is used for the robot.
I am going to guess from that statement that a second camera connected to the Dlink would not allow image processing that only the camera connected to the input port on the Crio would be available for processing. Does that work for your application?
Al
WB9UVJ
www.wildstang.org
________________________
Unread 19-01-2011, 20:17
AKA: noops
Yes it does in fact. The second camera on the arm will not be used for processing image, only for the driver's convenience. Attaching it to the D-link should be fine then. I was already looking into connecting an Ethernet Switch onto the network Camera port on the cRIO, but that would not allow me to program both cameras differently. Is there a guide to connecting the camera to the D-link? If I recall correctly, there is only one ethernet port on the Wireless Receiver (unless using an ethernet switch in this case works)
Unread 20-01-2011, 07:34
Unsung FIRST Hero
Rookie Year: 1996
Anupam,
I would recommend you practice with a camera as you propose before you really commit. It is hard on a driver to switch focus in a short match. You may find it is rarely used and not worth the effort.
Al
WB9UVJ
www.wildstang.org
Unread 20-01-2011, 08:55
tonystark_23's Avatar
tonystark_23 tonystark_23 is offline
FRC #2975
tonystark_23 is an unknown quantity at this point
The D-Link comes with 4 LAN ports on the back. So you can connect the cRio plus 3 other devices. Hope this helps!!
PS: Maybe have the 2nd camera on a different tab in the drivers station to not confuse the driver.
Unread 20-01-2011, 19:41
AKA: noops
Al,
The driver team is set up so that one driver will be controlling the arm, while the other controls the actual drive train, so each one will be seeing only one camera, and the second one may not be useful at all in some matches, but critical in other matches, as it provides the viewing angle for the person controlling the arm and end effector of the robot. Also, would R3 prevent me from placing an ethernet switch on the linksys receiver and having one port go to the cRIO and the other going to the camera?
Unread 22-01-2011, 08:31
Unsung FIRST Hero
Rookie Year: 1996
If I understand your question, the Linksys is no longer allowed. The Dlink is the new wireless adapter and it has four ports.
Al
WB9UVJ
www.wildstang.org
Unread 22-01-2011, 18:08
AKA: noops
I was referring actually to the WLAN receiver on the robot, not the router to broadcast the network.
Unread 23-01-2011, 01:54
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The D-Link DAP-1522 router is the wireless networking device on the robot. It's there to "broadcast the network" so your Driver Station (and programming computer) can connect to it. There is no other router, access point, or bridge used in the control system this year.
Unread 23-01-2011, 09:38
Unsung FIRST Hero
Rookie Year: 1996
As Alan has pointed out the Dlink is your new robot radio and a router thrown in. Take your old linksys home or put it too good use somewhere else. It cannot be on the robot this year.
<R52> One D-Link DAP-1522 is the only permitted mechanism for communicating to and from the ROBOT during the MATCH. All signals must originate from the OPERATOR CONSOLE and/or the Field Management System, and be transmitted to the ROBOT via the official ARENA hardware. No other form of wireless communications shall be used to communicate to, from or within the ROBOT (e.g. radio modems from previous FIRST competitions and Bluetooth devices are not permitted on the ROBOT during competition).
Al
WB9UVJ
www.wildstang.org
Unread 23-01-2011, 12:34
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
My question is: "Is it legal to connect one or more cameras to the D-Link in order for the robot to do image processing from 2 cameras ((either symultaniously (for stereo vision) or independantly (for line/target tracking)"
It's clear that the camera is normally plugged into the cRIO port 2, but is it legal to plug another one into the D-LINK?
I think the cRIO code should be able to access either one (just with different IP addresses).
My reason for a second camera is that there are some VERY COOL camera-based line tracking code examples on NI and I'd love to try them, but I don't want to have to pivot the camera up for Peg tracking.
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 26-01-2011, 07:22
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
So we can use a second camera if we put it our cots/bill of materials?
