Go to Post This just goes to prove there was life before FIRST (but it wasn't as much fun!) - Ken Loyd [more]
Unread 01-17-2011, 06:52 PM
WillF WillF is offline
Team Captain
FRC #2945 (B.A.N.G (Bolts and Nuts Gang))
Team Role: Leadership
WillF is an unknown quantity at this point
Windriver WPILib Build Issues
So we have been trying to get a program up and running for the robot. Unfortunately we have run into a little snag. Whenever we try to build the program it stops at
# include "WPILib.h"
Our theory behind this is that the subdirectories of C:/windriver/vxworks-6.3/target/h are not included in the build path. WPILib.h is in one of the subdirectories. Has anyone else run into this problem? Does anyone know how to set it so that the build paths are recursive?
Unread 01-17-2011, 10:12 PM
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
Rookie Year: 2007
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Windriver WPILib Build Issues
Not sure if this is just formatting you used for your post on this forum, but there should be no space between # and include, example:
Code:
#include "WPILib.h"
Here's a piece of our in-house documentation regarding the proper build paths:
9. Switch to the Build Paths tab
Add the following Include directories under Include paths
-I$(WIND_BASE)/target/h
-I$(WIND_BASE)/target/h/WPIlib
-I$(WIND_BASE)/target/h/wrn/coreip
10. Switch to the Libraries tab
Add the following Library directives under Libraries
$(WIND_BASE)/target/lib/WPILib.a
EDIT: If neither of these solutions are working, please post the full build error you are receiving.
Unread 01-18-2011, 07:27 PM
Team Captain
Well, that did the trick. Thanks
