Go to Post Dang. There goes the hint that was supposed to go out next week. Gotta start over now.. - dlavery [more]
Unread 18-01-2011, 02:52
Josh Adkins's Avatar
Josh Adkins Josh Adkins is offline
FRC #3138 (Innovators Robotics)
Team Role: Leadership
Josh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud ofJosh Adkins has much to be proud of
Alternative Banebot gearbox
Team 3138 started looking for an alternative gearbox for the Banebot Rs-395 since there is an absence of a usable gearbox from Banebots. We found that an FTC gearbox easily adapts to the Rs-395. Here are the steps:
You need one FTC motor and the Banebot Rs-395.
Step #1:
Step #2:
*Be careful not to smash the gear with pliers!*
Step #3:
This is by far the hardest part of the project. The shaft diameter of the Rs-395 is .09 whereas the inner diameter of the pinion gear is .095.To use get the pinion to press firmly onto the shaft we filled the hole in the pinion gear with solder and drilled the hole back out to .086(#44). I am sure their are better ways of doing this step (maybe an apoxy), but this was quick and we had everything we needed on site. Once you get the gear pressed onto the shaft it will need cut down to almost flush with the gear.
step #4:
step #5:
Attach the motor mounting plate to the Rs-395 using the screws that originally attached the FTC motor to the plate.
step #6:
Although this works I am in no way vouching for its reliability. We have ran the motor, and the output shaft turns from 200-300rpm. It seems to have sufficient torque for our purposes, but we have done no rigorous tests on the setup.
Unread 18-01-2011, 07:16
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Alternative Banebot gearbox
Usable or not that's a great smashup.
You should write a white paper and post it on CD.
Unread 19-01-2011, 13:10
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
Rookie Year: 2007
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
Sounds like a great opportunity for JB Weld
