Go to Post If you ever find yourself thinking that you are the most brilliant person in a situation, you are doing something wrong. - EricVanWyk [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 18-01-2011, 08:46
Techwiz's Avatar
Techwiz Techwiz is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
Rookie Year: 2007
Techwiz will become famous soon enough
Using the NXT Light Sensor.
Does anyone know how to get data from NXT sensors VIA I2C?
We hooked a light sensor to the I2C port on the Digital Side Car, and the red LED illuminated.
In Java:
Code:
byte[] byte1 = new byte[100];
ls.read(0, 7,  byte1);
for(int i= 0; i < 100; i++)
System.out.println(byte1[i]);
Note: Ls is defined as an I2C in the Constructor:
Code:
four = new DigitalModule(4);
ls=new I2C(four,0);
Thanks,
Blake
Electrical, Programming and Design
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 18-01-2011, 09:06
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: Using the NXT Light Sensor.
The Short answer is, You can't.
The Long answer: The NXT Light sensor doesn't use I2C to communicate. The only sensor that does, is the ultrasonic sensor. If you really wanted to use the light sensor, you should be able to hook it up to the analog Module.
Unread 18-01-2011, 09:23
Techwiz's Avatar
Blake B
AKA: Blake
Rookie Year: 2007
Do you know where we can get a pinout, for the sensors?
and or directions to hook it up to the analog module.
Blake
Unread 18-01-2011, 10:14
Bot190's Avatar
The documentation for The NXT brick, and the sensors is available from http://mindstorms.lego.com/en-us/sup...s/default.aspx under the hardware development kit. You should be able to figure out the pinout from those documents.
