Go to Post Is it legal? Yes. Is it Graciously Professional? Yes. Is it smart? No. - dlavery [more]
Unread 18-01-2011, 14:15
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
Rookie Year: 2007
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
Potentiometers
Is there any limit to the resistance that a potentiometer wired up to the Analog Breakout can have?
The team is everything.
Unread 18-01-2011, 14:44
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
Re: Potentiometers
If you're asking about an upper limit, I would say around 10 kilo-ohms, but you could probably get away with a 50 kilo-ohm pot. Each input has a 1 mega-ohm resistor inline.
If you're asking about a lower limit, that is about 20 ohms if it's the only thing on the analog breakout. The limitation is that the 5v supply on the analog breakout has a 300mA limit.
So, anywhere between 300 ohms and 3,000 ohms is great.
-- Marshal Horn
Unread 18-01-2011, 14:48
1951-44U's Avatar
ROAR.
AKA: Phil Chang
Rookie Year: 2007
Re: Potentiometers
Exactly what I wanted. Thank you!
Unread 18-01-2011, 14:52
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Potentiometers
Not really. Just about anything you can find on the shelf is likely to work. I'd recommend choosing something in the 2k-20k range.
The lower limit is set by how much power can be drawn. Lower resistance draws more power (Power = (5 Volts)^2 / R Ohms). You have about 1W total to play with, which would limit you to 25 Ohms - but that would be kinda silly. Why waste all that power? 1k is good enough lower bound here: 25mW.
As you increase pot resistance, your power consumption goes down but you become more sensitive to other sources of error. The one that will eventually limit you is the input impedence of the NI-9201 - it draws a tiny amount of current to measure the voltage, which can affect the voltage that it is measuring! As a rule of thumb, you want this to be about an order of magnitude of margin. Fortunately, the NI-9201 has a really nice input impedence of 1 mega-ohm. If your pot is less than 100k, you won't even notice it.
EDIT: Gah, beaten by Marshall again!
Unread 18-01-2011, 19:40
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Team Role: Mechanical
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Re: Potentiometers
Okay, so is there a particular type/brand of potentiometer that you know is reliable or works the best/well?
We are particularly looking at multi-turn potentiometers. I went to one website and they had over a thousand types of potentiometers.
Thanks,
Jason LaW
Unread 18-01-2011, 22:57
tagayoff's Avatar
tagayoff tagayoff is offline
FRC #3512
tagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the rough
Re: Potentiometers
Thanks,
Jason LaW
These are very reliable pots.
http://www.bourns.com/ProductLine.as...pots_multiturn
Unread 18-01-2011, 23:18
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Potentiometers
All I can advise is this: you get what you pay for.
Unread 18-01-2011, 23:33
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Potentiometers
We've used Vishay 534-1-1-502 10 turn potentiometers several times before.
