Line Following
Hello,
We are having some issues in programming the Line follower. We are using the Digital Input class and we can't get it to work. Can anyone give us a hand? Thanks in advance. |
Re: Line Following
Could you please post precisely what issues you have? The source code you are trying would also be of help for us to debug your issue.
Have you looked at the example code? If you go to File->New->Example in WindRiver and look under VxWorks Downloadable Kernel Module, there is some Line Tracking sample code. Make sure you have all updates installed, you will need them for the sample project to be visible. |
Re: Line Following
Oops, when we checked the example code for line tracking the first time, we must have skipped over it.
Re: Line Following
Re: Line Following
When I'm on a development machine I will look at the line leader sample in more detail - you can PM me if you need any help programming your robot for the 2011 season. |
Re: Line Following
Re: Line Following
Re: Line Following
somebody should update the eclipse plugin so you can right-click a .out and select "Deploy to Robot"
Re: Line Following
Something to check when I have a remote target to connect to... |
