Go to Post by the way when someone calles me a dork or geek, i tell them to look up dork and geek in the dictionary, and that i would rather be called nerd :) - Mike Schroeder [more]
Unread 18-01-2011, 20:30
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
Ratio Curve Arcade Drive?
Hello, my team would like to drive our robot this year using a system similar to how 971 had it. What they did was use a steering wheel for turning and a regular joystick to drive. When I was on the 2011 Game Project template I saw that there was an option on the arcade drive called ratio curve. Would this possibly be the driving code for what we want? If not, is there any example code written that will let us drive our robot like this?
2011-2014 Arizona Regional Winners
2012 Dean's List Winner
2012-2013 Team President
2013 8th Place Robosub Competition
2014-? Mentor
Unread 18-01-2011, 22:20
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Ratio Curve Arcade Drive?
I don't have a copy of Labview this year to verify this, but if I recall correctly ratio curve is used to define the mapping between joystick input and robot output. Many teams use functions like x^2 or x^3 to improve fine control while maintaining the same top speed. Using that should not be necessary for what you want to do.
What you want to do should be easy to accomplish. The steering of arcade drive is controlled by the x-axis input so wire the appropriate axis of your steering wheel "joystick" to that. The throttle is controlled by the y-axis input so wire the y-axis of your joystick (I can't recall the numbering) to that input on the arcade drive.
Unread 20-01-2011, 14:05
Jester Jester is offline
Labview Maniac
AKA: Cody Ripley
FRC #3144 (Krypto-Knights)
Jester is an unknown quantity at this point
I think the steering wheels have 1 axis, the X axis. Hook it up to either your rotation or X input on arcade drive.
Y-axis is axis #2 on most joysticks.
