Go to Post Thanks to ... Dave, who teaches us not to worry, it’s only rocket science. - JohnBoucher [more]
Unread 19-01-2011, 14:33
Valencia Valencia is offline
FRC #3705
Valencia is an unknown quantity at this point
how to setup the encoder?
How would you setup the encoder and place it in the robots
and how would it work?
Unread 19-01-2011, 15:55
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: how to setup the encoder?
To which encoder are you referring?
Unread 22-01-2011, 15:00
FRC #3705
How do you set up the US Digital E4P encoder? We also need the sample program in C++ to control the encoder.
Unread 23-01-2011, 01:50
Software Architect
Are you asking about mounting it mechanically, or about connecting it electrically?
Electrically, it has four wires. The "A" signal, +5, and GND go to one DIO connector on the Digital Sidecar; "B" goes to the SIGnal pin on another DIO connector.
