Go to Post I didn't say this! - Max Lobovsky [more]
Unread 19-01-2011, 15:28
cheezburger's Avatar
cheezburger cheezburger is offline
FRC #0686 (Bovine Intervention)
cheezburger is an unknown quantity at this point
Holonomic Drive Program
My team is switching to Java this year and we want a holonomic drive system.
Not quite sure how to program it. When we tried to use the holonomicDrive method, Netbeans gave us a slew of errors, the most common of which was that
"holonomicDrive(float, float, float) is not public in edu.wpi.first.wpilibj.RobotDrive; cannot be accesed from outside package."
This is the code we have:
public void operatorControl() {
while (true && isOperatorControl() && isEnabled()) // loop until change
drive.holonomicDrive(leftStick.getDirectionDegrees (), leftStick.getMagnitude(), rightStick.getX(GenericHID.Hand.kRight));
Timer.delay(0.005);
I'm open to help in fixing holonomicDrive or to help in making a holonomic from scratch, as long as it works. The place I got the current code from said it was not tested code. I'd like code that has been known to work.
i can has cheezburger?
