Go to Post I used to think FIRST was about my learning experiences, but now that I'm out of high school and am a seasoned veteran of FIRST I've realized that this organization is about more than my own enjoyment, it's about the enjoyment of others. - Jeremiah Johnson [more]
Unread 20-01-2011, 01:29
114Klaatu0x72's Avatar
114Klaatu0x72 114Klaatu0x72 is offline
DQN
AKA: Sean
FRC #0114 (EagleStrike)
Rookie Year: 2007
114Klaatu0x72 has a spectacular aura about114Klaatu0x72 has a spectacular aura about114Klaatu0x72 has a spectacular aura about
Send a message via AIM to 114Klaatu0x72
Re: Never Do This, and Other Good Ideas Gone Bad
During Overdrive, our team decided on using a pivoting arm with one or two 80lb constant force springs, along with an underpowered gearbox, Chinese cast iron gears and "pwm cables" aka painted string, and a broken anti-back drive mechanism. It worked about once, and then the gears sheared off half their teeth, the anti-back drive pins fell out, and a cim burnt out in the manor of seconds. We switched out all of the motors with pneumatics between two competitions, and some of our problems went away. Later that year it knocked me out twice from a blows to the head, one time during a presentation to a middle school, as well as being just terrifying to be around in general. All of those problems pretty much stemmed from a few simple issues: a lack of prototyping, a love of cheap parts, and miscalculations in math. If we spent another week prototyping and a few hundred more dollars, and double-triple-well-beyond-the-point-of-redundancy checked our math, we could have done great that year. So, pretty much anytime you think something will work, despite how sure you are of it, try it and make sure it works.
Also, large amounts of force absolutely suck to work with, try to avoid designs that use them, as they tend to fail in some way after a sometimes very short while.
Unread 20-01-2011, 02:41
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
I'm curious about the gear specs and the load you put on those gears; would you mind explaining further? (Besides, I also want to know the supplier of the gears, so that I can consider avoiding them!)
Originally Posted by cire View Post
2003... Never use #25 chain for your drivetrain. It may seem like you will never hit that several hundred lb limit, but when you throw in missalignment and shock loading, well lets just say we went through a lot of chain that year.
188 broke about 13 strands of ANSI #25 in 3 events that year. Of course, we didn't exactly have the best setup—small drive sprockets on very powerful transmissions,* rigid and convoluted chain guides instead of idlers, and a bit of misalignment.
On the other hand, on a different drivetrain, ANSI #25 chain can be a perfectly reasonable choice—this year, for example, with all the high-speed driving, teams can probably expect substantially less chain load, especially if they've got room for big sprockets on their big wheels.
*Actually, as far as I know, they were the most powerful transmissions on any FIRST robot to that point; each transmission had a CIM, a Bosch drill motor and a Fisher-Price motor.
Unread 20-01-2011, 06:25
DQN
AKA: Sean
Rookie Year: 2007
I don't have the exact gear specs, but I beleive the gears which broke were something attune to:
*80 and 16 tooth
*face width of a quarter inch
*14.5 or 20 degree presure angle
*pitch of either 16 or 20
*Made of cast iron, cheap cast iron.
There was maybe about 20 to 40 ft-lb of torque going through them, but its hard to say exactly because really nothing is left of that robot (cad, docs, notes, pictures) excpt for a stripped out frame and a single, half bald gear on our wall of shame. As for where we bought them, all I remember was that they came from some Chinese distributor and had BOSTON embosed in them. Unless you are constantly looking up cheap items and can read Mandarin, you probably won't come accross them.
Unread 20-01-2011, 07:27
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
Based on my years on Aces High (FRC176) and Division by Zero (FRC229) heres my list of things to avoid in season:
Never Agains:
1. Sissor Lifts
2. Tank Treads
3. Vaccuum Devices
Avoid at nearly all costs:
4. Cast Iron Worm Gears
5. Gravity Fed Hoppers
6. Gravity Dependent Lifts/Arms
And until done completely and perfected in an "offseason"
7. Crab Drive/4 Wheel Steering/Holonomic Drive
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Unread 22-01-2011, 07:41
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Team Role: Mechanical
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
In 2008 we used a pogo- stick and pneumatically actuated arms. It had 6 wheels with two omnis in the front, and chains to drive them. Unfortunately, the arm couldn't grip the ball tight enough, the chains were too heavy, and the pogo stick needed more repairs than any part on any robot since then.
--Don't be stupid, it's not smart.
--In conclusion, I conclude that the conclusion was conclusive.
Unread 06-02-2011, 16:29
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Never change your design with only two weeks until ship date.
Unread 06-02-2011, 16:37
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Not sure about this one. There have been plenty of teams that changed their design late in the season or during the season and have done very well. The best example of this is probably World Champion 67 in 09. Just off the top of my head others include 469's gripper in 07, 2039 in 09, 33 in 09, 16 in 09. All of those teams either won regionals or made it to the eliminations at the championshop with their new design.
Unread 06-02-2011, 17:06
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Don't change your design unless you really have to and can put in the man hours to make it work. The wrong thing well is better than the right thing badly.
Examples of "you really have to" would include the pincher rollers of 2010. Every competitive team last year at least considered that change, I guarantee it.
Unread 13-06-2011, 22:23
Alex2614's Avatar
Alex2614 Alex2614 is offline
Scapegoat Mentor
AKA: Alex Stout
FRC #2614 (MARS)
Alex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud ofAlex2614 has much to be proud of
Send a message via AIM to Alex2614
Originally Posted by IKE View Post
I will let someone else cover scissor lift.
Ugh... don't even get me started on the scissor lift.
MARS - Mountaineer Area RoboticS Team 2614, Morgantown, West Virginia Website Facebook Page
2016 season in memory of Phil Tucker
We came to be inspired. We stay because we are. We will become the inspiration.
2016 Championship - Newton quarter-finalist, Hopper-Newton Gracious Professionalism Award
2016 Regionals - Finalists (x2), Chairman's Award, Gracious Professionalism (x2), Industrial Design
2015 Championship - Hopper Finalists
2015 Regionals - Chairman's Award, Regional Champions, Gracious Professionalism, Woodie Flowers Finalist
2014 Championship - Innovation in Controls Award
2014 Regionals - Chairman's Award, Champions, Finalist, Entrepreneurship, Gracious Professionalism, Dean's List Finalist, Creativity
2013 Championship - Entrepreneurship Award
2013 Regionals - Engineering Inspiration Award, Entrepreneurship, Dean's List Finalist
2012 Championship - Woodie Flowers Award
2012 Regionals - Champions, Chairman's Award, Finalist, Innovation in Controls
Unread 01-10-2011, 01:02
Andrew Lawrence
Posts: n/a
Go to a competition without replacement parts, including an extra minibot.
At SVR this year, the small gear that controlled our who arm system snapped in two after a team hit it with their claw (accident, of course!). We had no other gear to replace it with, and spent the remainder of the competition playing defense (which we weren't that bad at).
Also, our minibot got executed. During yet another collision, our minibot somehow fell off our robot, got stuck under our wheels, and got half torn apart by us. Then, once we got off, the other teams, including our alliance, ended up running it over 1 way or another (again, all accidents)!
To anyone who attended SVR this last season, if you found a neodymium magnet attached to you your robot somewhere, and you went against 256 in a match, can we have it back?
Unread 01-10-2011, 01:56
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
So far I would have to say my worst experience was 8020 elevators... But thats me.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 01-10-2011, 10:18
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Last year we had excellent success with Bosch Extruded (e.g. metric 8020) -- totally rocked the Finger Lakes Regional with a highly successful endgame. (I think we failed to lift only twice, and both of those times were because of issues totally unrelated to the performance of the lift itself!)
Bosch has slide carriages that fit their 30mm extruded and work extremely well. We used more of it this year for our minibot deployment.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 01-10-2011, 13:08
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
80/20 (and maybe Bosch too) sliders really start to bind on multi-stage compound elevators. You also have to keep the 80/20 perfectly square to minimize binding, and at height there's a higher tendency for torsion. We scrapped 80/20 in favor of powder coating + teflon for slide friction that was close to what a bearing slide would have; the box aluminum also resisted torsion alot better.
GitHub
Unread 01-10-2011, 16:40
pfreivald's Avatar
We have not had even a single issue with Bosch slider carriages binding on multi-stage compound lifters -- and from trackballs to minibots to entire robots, we've really put them through their paces! I can't speak for 8020.
Team 1551
I write books, too!
  #15   Spotlight this post!
Unread 04-10-2011, 16:00
Kyler386's Avatar
Kyler386 Kyler386 is offline
I'm software, it's not my problem.
AKA: Ky
FRC #0386 (Team Voltage)
Kyler386 is an unknown quantity at this point
I don't know if the majority of my team would agree with me on this, but here's what I think:
2006: No more turret designs. According to members & alumni, 06 was an all around horrible year, robot and all.
We broke this rule in my first year. (2009) Needless to say, our robot scored once that whole year.
2010: Do not try to stop a pnumatic cylinder halfway. We had a "Bump Mode" that allowed our robot to go over the bumps. To do this, we had to activate our pnumatic kicker, and then immediately bring it back about halfway so that the kicker would clear the surface of the bumps without the kicker breaking the plane of the bumpers. Sounded good in theory, (which, according to a forum regular, is a nice place) but it did not work in the real world.
And the new one for Logomotion: NO MORE BUMPER SKIRTS!!! Those things are horrid.
Funny, the part of our LV code that looks nice doesn't work, but the code that is so horrid, you can't tell what's going on, works perfectly...
