Go to Post Eventually, the "less effective" tweaks will settle to the bottom, and the more effective ones will be assimilated by the group. Then someone will tweak the tweak. That's when the fun begins. - Billfred [more]
Unread 19-01-2011, 16:01
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Never Do This, and Other Good Ideas Gone Bad
So the scissor lift reminded me that there are a lot of designs experienced teams have tried once, and forever sworn off. This thread is meant to be a compilation of "Ideas gone bad" especially the ones you see year after year. Add your Gone Bad designs, and please explain details:
I will let someone else cover scissor lift. My favorite is the big hopper of balls with a single slide open door. These always work in your head, and they always fail in practice. Typically FIRST picks a compliant ball that wedge together and jam at the exit. This leads to frantic ramming in order to unjam the hopper.
Unread 19-01-2011, 16:07
Numbers's Avatar
Numbers Numbers is offline
Cyberdemon
FRC #3238 (Team Red)
Rookie Year: 2010
Numbers is an unknown quantity at this point
Send a message via MSN to Numbers
Re: Never Do This, and Other Good Ideas Gone Bad
No idea what you're talking about with scissorlifts. Our team's rookie year was 2010, and we had great success with our scissor lift (Designed to climb the tower).
Unread 19-01-2011, 16:13
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is online now
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
I know my former team, 27, in both '06 and '09 refused to do an Archimedes screw after what happened to them in '02. I don't think they'll ever return to that idea. It does have great potential though, it's made it to Einstein, it's all about implementation I guess.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 19-01-2011, 16:27
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
Rookie Year: 2007
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
I agree, it's more the implementation than the idea. Several years before I joined the team, they created a robot that remains infamous to this day. Its name was Scorpio. In 2009, several ideas were thrown out because they had failed on Scorpio. In competition, though, we saw them done well. The implementation was flawed, not the concept.
GSR Dean's List Finalist 2011
Unread 19-01-2011, 16:33
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Our team will not likely use vacuums, or conveyor belts due to flawed execution and/or excess time we spent fixing parts. We will also never make a robot with less than an inch of ground clearance again (got stuck on the field repeatedly last year).
I agree that almost anything can be successful if done correctly, some ideas are just more difficult to implement than others.
Unread 19-01-2011, 16:45
Jonathan Norris Jonathan Norris is online now
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Cantilever shafts, try and avoid. Especially over 1.5"-2", try and support both ends of shafts.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 19-01-2011, 17:20
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Originally Posted by Jared341 View Post
Relying on gravity to do anything other than to give your robot weight. If it moves down (an arm, an elevator, a ball in a hopper), make it powered.
I would argue with this one... If designed correctly, you can rely on gravity. The elevator we built in 2008 was powered up, and gravity down, and the only time it failed to work as anticipated was when the motor literally broke off its mountings at a pre-ship event. Other than that, it always went up AND down when we told it to, at a consistent, reliable speed.
Unread 19-01-2011, 17:31
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
I accidentally tip your robot over with your gravity-down lift up. Oops, your lift doesn't go down anymore.
330 always adds a "gravity" cable to lifts for the case where you're tipped over and you need to unblock the field. It also helps to retract the lift for other cases like hanging on a bar. It's not that hard to add to the drum, either, if the winch is sized right.
Scissors lifts can be really nasty to get right. If you do get them right, they work OK... but they do have their weaknesses. I've seen a single-joint arm clean game pieces off the top of a scissor lift with one sweep, back in 2005. Hit a scissors lift so that it sways and... well... not pretty.
330 does have one team rule: All deployables shall be retractable (exception--we decide it's not necessary to pull them back in). Reason: We don't want to have to be dragging something around all match because it deployed too early by accident--and it's really surprising when we pull up ramps and go defend a spoiler (2007) or do other similar things.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-01-2011, 17:35
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
What difference does it make that a gravity-lowered lift no longer works when the robot's been tipped over? Talk about not seeing the forest for the trees.
It's usually not difficult to power lifts in both directions and it's sage advice to do that whenever possible, but not doing so is not necessarily a catastrophic decision. There are all sorts of things that can be done to mitigate any problems that might arise from relying solely on gravity.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 19-01-2011, 17:45
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
If a gravity-lowered lift is up, and the robot is tipped over, that lift is now blocking the field. Because it's gravity-powered, it can't go down (robot-relative) any farther. This can lead to penalties (the 84" cylinder, for example--a gravity-lowered lift that falls over while trying the top peg could easily be over 84" from the floor, causing a cylinder violation) or difficulty in getting the robot upright (longer moment arm, so more motion needed to go the same rotation).
If it could be pulled down relative to the robot (not the floor), then there is less chance for penalties, it's easier for a partner to get the robot upright, and depending on design, the robot itself may be able to assist the righting process.
There have also been some comments--some time back--that dirt could jam the guides, or some other such things, that would interfere with gravity.
Can you mitigate it? Sure. But Murphy says that the problem will happen when the mitigation isn't happening right.
Past teams:
Unread 19-01-2011, 22:30
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Nope - the cylinder falls over with your robot.
Originally Posted by <R07>
(note: these limits are defined in reference to the ROBOT, not the FIELD).
(since 2004)
Unread 18-01-2012, 17:39
ChocolateDragon's Avatar
ChocolateDragon ChocolateDragon is offline
FRC #1165 (Team Paradise)
Rookie Year: 2012
ChocolateDragon is an unknown quantity at this point
What about the conveyor belt you tried didn't work? Was it the flawed execution, or the excess fixing time, or some other reason?
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Historically, Drive-trains have not been our strong suit.
In 2002, 2004, and 2005 we used 4 wheel drives using rubber wheels on all 4 corners in a long base configuration. None of those robots turned very well at all, and one of then had a tendency to leave the ground while attempting to turn...
In 2006 and 2007 we decided we were going to try out Omni Directional wheels coupled with IFI High Traction Wheels. For some reason, still unknown to me, we chose not to power the omni wheels and only powered the traction wheels... These didn't turn all that well either...
Since then, there have been two unspoken drive-train rules on our team: No long base 4WD and No Un-powered Wheels.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 19-01-2011, 16:31
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Ditto scissor lifts and "many-to-one" hoppers. I've seldom (but not never) seen implementations of each that were effective.
Mecanum wheels are on the verge of making the list, too (for the same reason).
  #15   Spotlight this post!
Unread 19-01-2011, 16:40
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
I think this is true for pretty much any design idea. There are few designs that are universally bad in all cases. A design may be poorly suited to a particular game, or the team may fail at execution, but given the right situation and great implementation, even the much-maligned scissor lift can be done successfully.
That being said, I do have a list of designs I will avoid unless I REALLY am convinced they're necessary. Among them are: mecanum drive, holonomic drive, scissor lifts, the aforementioned "big hopper of balls" with a single (small) door, 3+ axis arms, and high reduction BaneBots gearboxes on high-torque applications. Most of these I learned firsthand, over my college years.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
