Go to Post It's a good things we're engineers who regularly squeeze out 'miracles' with a severely limited budget, eh? I think that's an important aspect that we as mentors need to show the students from time to time, and this year is a perfect opportunity. - JesseK [more]
Unread 19-01-2011, 16:31
Matt Daioh's Avatar
Matt Daioh Matt Daioh is offline
FRC #3501 (Grinders)
Rookie Year: 2011
Matt Daioh is an unknown quantity at this point
cRIO help
Hi everyone
Our team was imaging our cRIO and following the directions as provided on the manual. But then when we got the cRIO connected, my partner clicked apply before we could follow steps 3-8. It said that it successfully connected.
Now when we try to connect the cRio to the laptop, it says it cannot connect. Do we need to restore our cRio to factory settings or is there some other task we need to do? We are a rookie team, so any help would be appreciated!
Thanks
Unread 19-01-2011, 17:27
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: cRIO help
The cRIO Imaging Tool running on your laptop is telling you it cannot connect?
Here are some directions that might help: http://www.chiefdelphi.com/forums/sh...68&postcount=3
Unread 19-01-2011, 19:22
Matt Daioh's Avatar
Rookie Year: 2011
Re: cRIO help
The Imaging tool does not recognize the cRio. We tried your instructions, but it still did not recognize it.
The Imaging tool did recognize the cRio, but it couldn't recognize it after we pressed apply too early and imaged it without the options we need.
Do we need to reset the cRio to its factory settings to remove the wrong image?
Unread 19-01-2011, 21:58
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: cRIO help
Well make sure your cRio has power going to it, then make sure that the cRio is tethered to your computer, and the NI imager should see the cRio and you should just be able to reimage it.
Unread 20-01-2011, 17:06
Matt Daioh's Avatar
Rookie Year: 2011
Re: cRIO help
well, merci beaucoup monsieur
We have, in fact, been powering the cRio, connecting it to the computer, and running the imaging tool, but our problem persists
Unread 20-01-2011, 22:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: cRIO help
Exactly how are you connecting the cRIO with the computer? Which cRIO port are you plugging into? Have you turned off all other networking on the computer?
Unread 21-01-2011, 14:45
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Rookie Year: 2007
Straberrie will become famous soon enough
Re: cRIO help
Hey, we had the same problem.
Do the following:
1) Press the IP-RESET Switch on the cRio.
2) Hold down the Reset Button
3) Let Go
4) Connect a crossover from your computer to the cRio
5) Try the re-imaging the cRio again
You may get Error 7 from your cRio. We did, but it dissappeared once we tried re-imaging again.
Did you by any chance try loading the code before you reset the cRio after re-imaging? I do not know if that would cause the problem, but that's what happened to us.
Hope this works!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
