Go to Post In engineering, it's important to use the appropriate tools and not more resources than are required. - AdamHeard [more]
Go Back   Chief Delphi > Technical > CAD
Unread 19-01-2011, 19:25
vincentkee vincentkee is offline
FRC #0687
vincentkee is an unknown quantity at this point
Location of Mounting Holes on Banebots Bearing Block
Does anyone have the Banebots Bearing Block, 2.5 x 2.5 inch, 0.5 inch, with Ball Bearing (PB-S5002-BB)?
http://banebots.com/pc/MOTOR-ACC/PB-S5002-BB
It doesn't specify the location of the 1/4-20 mounting holes on the website.
Does anyone happen to know the locations?
Thanks
Unread 21-01-2011, 22:00
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Re: Location of Mounting Holes on Banebots Bearing Block
Happen to have one in front of me.....
The four on the side make a square that is 1.5" center to center.
The two on the bottom & top are approx 9/16" from the edge to center, 1-3/8 center to center.
Unread 18-04-2011, 17:18
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
reported
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
