Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Unread 01-02-2011, 16:49
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Re: Tetrx Minibot Battery Charge Cycle during Regional Play
Al,
Attached is the discharge curve comparison you requested. One curve shows a discharge rate of 2 amps and the other shows a rate of .9 amps.
It seems there is not a big difference.
-Hugh
Unread 20-01-2011, 22:57
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Originally Posted by Hugh Meyer View Post
Chris,
Here is a discharge curve I did on one of ours. It shows good response down to about 1.6 AmpHrs, then below that it starts down hill. It looks like any calculations for life should us 1.6 AmpHrs as the useful life. This is with a discharge rate of 2 amps.
It looks like it will be important to carefully manage battery usage. We will likely top them off between matches and alternate batteries.
-Hugh
That's pretty impressive that this battery hangs on to the voltage for that long in the upper 12 volts. That should keep the minibots pretty consistent in the race to the top even on a so-so charge. Nice work Hugh!
PS: We've been wanting to get one of those CBA II analyzers ourselves. This year might be the year...
http://www.batteryjunction.com/western-cba2.html
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 21-01-2011, 16:57
chemipanda chemipanda is offline
Budha
FRC #0240 (TEMPEST)
Team Role: Mechanical
chemipanda is an unknown quantity at this point
How long should it take to charge the battery for the first time?
Unread 21-01-2011, 20:19
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Ours took 4 hours to charge when new from the box. that was when the charger light turned green. The battery pack was warm at 3h45m and warmer at 4hours.
BTW, I taped a piece of clear plastic with a small hole for the slide switch over the indicator and switch area of the charger. This will keep the small slide switch from reaching the 1.8amp charge rate position by accident.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 21-01-2011, 23:19
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I'm attempting a synthesis of this thread and the dynomometer test results reported on this thread.
A >14V supply gives 40-50% extra power output compared to a 12V supply.
So while the flat 12.5V profile between 0.4 and 1.0Ah is nice, keeping the battery at less than 0.1Ah discharge seems to be the best competitive policy.
Caveat: My knowledge of battery technology is limited, so corrections are welcome.
Unread 01-02-2011, 17:20
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
A CBA II is one of the best investments we ever made. We haven't had a battery related issue since we got it. We test and rank all our batteries before every competition.
Unread 01-02-2011, 17:32
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Chris,
I bought mine at West Mountain Radio, the manufacturer. Of course they are a great source for Ham Radio stuff too. I hope they get a lot of business and stick around.
Al
WB9UVJ
www.wildstang.org
________________________
