pic: 2791 Chassis (Not A Teaser)
Re: pic: 2791 Chassis (Not A Teaser)
Looks good! How heavy is the frame?
Looks awesome.
I'm curious about weight as well. |
What diameter wheels?
Why internal belts?
Weight: Honestly have no idea. I didn't do the chassis CAD and when I got a brief look at it today the material properties weren't set. The chassis parts are out of shop now but the second they get back I'll weigh them. It won't be the lightest thing in the world, but we prefer weight down low - with a 9 foot high arm having such a low CG will be immensely helpful.
The wheels are 4" diameter. Gotta love a flat field, right? The belts are internal for a few reasons. First, internal belt loops are cleaner and less in the way; the less space we take up in the center, the more room we have for things like electronics and our minibot deployment system. Second, they are less "open" so field debris cannot possibly get tangled with them. As for the drawbacks to internal belts, we saw them and minimized them. Maintenance was a big worry for me, but I'm now convinced it'll be not a problem. We tested these belts rigorously. Rapid speed changes, stalling the motors, mixes of both, and the belts did not skip or strip even once. Also, tensioning is not much of a problem. We have some fairly basic idlers in there for tension and it's a very much "set it and forget it" thing - once you get the belts right you never need to touch them again. Just in case, we did a timed run for a full belt change and it took about 7 minutes. We weren't satisfied, so we added the access window over the middle row, which is where most if not all of the holdup was. It should now be under 5 minutes to change a belt, and we plan on practicing those belt changes. |
Are all the internals from Gates belting? Or did you use something else? Just curious.
Yup, all Gates. Can't beat the price.
What pitch/belt width?
-Brando |
#11
We are using a 9mm wide 5mm pitch belt.
