Go to Post If you don't like contact, your robot is not built well enough. - sanddrag [more]
Unread 20-01-2011, 15:04
Tommithy Tommithy is offline
FRC #2410
Tommithy is an unknown quantity at this point
Driver Station Coding
This is the first year we are doing a dashboard interface, does anyone have any examples to guide us?
BLARG!!!
Unread 20-01-2011, 15:06
FRC #2410
Re: Driver Station Coding
Also if anyone has any tutorials, that will be really helpful =)
BLARG!!!
Unread 20-01-2011, 15:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The default Dashboard is written in LabVIEW. It's one of the "new project" options in LabVIEW for FRC. Laying out whatever indicators you want is very easy. Adding elements to the Dashboard Data cluster is tedious but straightforward, and once they are there it's simple to pull out the values and wire them to any indicator you want.
Creating a dashboard data stream from C++ is beyond my area of expertise.
Unread 20-01-2011, 16:03
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
Rookie Year: 1999
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Actually, I was looking for some assistance with streaming data to the stock dashboard from C++ too. I'm actually kinda surprised, the WPIlib changed little enough since last year that my 2010 code still compiles O_O so I'm spending a bit of the time I don't have to spend relearning the library to get this dashboard working. If anyone has any example code for getting a fully working dashboard output from C++ I'd be very grateful.
Unread 20-01-2011, 19:01
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
http://www.chiefdelphi.com/forums/sh...ad.php?t=77908
I ended up finding this^ after I had left robotics for work. Me and Anoop (Tommithy) will post back when we have something. If anyone else has any other examples, feel free to post!
~David
