Go to Post it isn't about the technology but about the teams working together. Sneaky GDC has done it again. - dtengineering [more]
Unread 20-01-2011, 17:21
pathogen4815's Avatar
pathogen4815 pathogen4815 is offline
There is no spoon
AKA: Tucker Baumgartner
FRC #1318 (Issaquah Robotics Society [IRS])
Team Role: Leadership
pathogen4815 is an unknown quantity at this point
Digital Side Car Ports Imput Problem
Allright, so we are programming our mechanum bot, and we have 4 sim motors and gearboxes, the digital sidecar and wires, the encoders, and Crio all hooked up. We are only getting encoder values on every other port on the digital side car (3,4 7,8 11,12) we replaced the wires, and the same thing happened. We cehcked the wires, and they are all working. We replaced the sidecar with a brand new one. We got the same pattern. So we replaced the Main Gray Cable that connects the sidecar to the module. Same thing..... We then replaced the actual modual. The same thing happened. We are stuck now. Anyone know what is wrong? We get a NAN reading on the ports that are not giving encoder values
Unread 20-01-2011, 18:09
zbanks zbanks is offline
AKA: Zach Banks
FRC #0529 (Mansfield Hornets)
zbanks is an unknown quantity at this point
Send a message via AIM to zbanks
Re: Digital Side Car Ports Imput Problem
How are you wiring them?
The red & brown cables are +5V/GND respectively, the blue/yellow are the only outputs. They're labeled A & B on the encoder housing.
(I'm guessing this is your situation since, if memory serves me correctly, red & brown are on the outside. Also, with 4 encoders, you should only need 8 inputs, not 16)
What language are you programming in? Are you using the built-in encoder class?
Unread 20-01-2011, 22:01
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
So I'm assuming you programmed all the DIO ports for the encoders? If not, you might want to recheck your program.
