Go to Post Robotics. Seems to be the answer to a lot of things I don't do. - Keith Chester [more]
Unread 20-01-2011, 18:48
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
Team Role: Leadership
Rookie Year: 2010
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
4 vs 6 wheels (what to choose)
We in team 3329 are apparently still in the process of choosing our drive system. We are debating 4 or six wheel drive, and I am leaning toward the 6 wheel because of the balance and weight distribution of our robot, especially if we are planning on making something to reach up to the top pegs. are those factors to take in with the selection of the number of wheels? It also may help to let everyone know that we are using almost the same design layout for the chassis as the kop, but we are re fabricating it in 1/8 in aluminum box tubing, because we had issues last year with the c-frame warping, and our robot was EXTREMELY light last year. So 4 or six?
Unread 27-01-2011, 11:45
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: 4 vs 6 wheels (what to choose)
Nowhere in the OP was "mecanum" mentioned. I believe the question is 4wd tank vs 6wd drive tank. I'd go with 6wd tank as it comes well packaged in the KOP c-base. If you decide to go 4wd have two of the wheels be slick or omni wheels, so that your robot can actually turn.
Good luck!
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 27-01-2011, 11:50
Bernoulli Bernoulli is offline
Bernoulli is an unknown quantity at this point
in all reality both of these have strengths and weaknesses however the way you go about your design ie: tank, omni, mecanum, swerve, crab will really determin which set up along with what you want it to ba able to do ie: manuvure, agility, strength, pusshing power, etc etc etc however it seems alot of teams have had success with a 6 wheel drive using 4 mecanum and 2 sticky wheels however its all up to how u want your robot to perform
Unread 27-01-2011, 11:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Surely you mean omni wheels? I've never seen a 6wd robot with 2 traction wheels and 4 mecanum, nor have I ever heard of one.
I may sound picky, but there is a big difference between a mecanum wheel and an omni wheel.
Unread 27-01-2011, 12:30
DinerKid's Avatar
DinerKid DinerKid is offline
AKA: Zac
FRC #1768 (Nashoba Robotics)
DinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of lightDinerKid is a glorious beacon of light
A huge part of picking a drive train is what you want it to do and how you plan to build around it. Last year we wanted to build a goalie-bot. We decided quickly that we wanted to have the robot oriented so that we could block with the wide side. We then decided that a wide kicker would be a good idea. For this design mecanum was a just. we wanted to be able to drive really fast between the two goals but also strafe forward and backwards in order to drive up to the ball in order to kick.
For this year if you are confident that your programmers will be able to write line tracking code that will get you in position to score maybe you go with a 6 wheel rocker.
If you think you will end up manually positioning the bot to score then you have a bit more to think about. On one hand you can spin a 6 wheel rocker to make adjustments (to a certain point) while mecanum will easily strafe to do the same thing.
There isn't really any way to say which one is better. It depends on what you are trying to do and how you are trying to do it. Thats what makes this engineering.
~DK
Unread 27-01-2011, 12:11
Mike Rizzo's Avatar
Mike Rizzo Mike Rizzo is offline
MAR District Supporter
AKA: Rizzo
FRC #1640 (Sab-BOT-age)
Rookie Year: 2000
Mike Rizzo has much to be proud ofMike Rizzo has much to be proud ofMike Rizzo has much to be proud ofMike Rizzo has much to be proud ofMike Rizzo has much to be proud ofMike Rizzo has much to be proud ofMike Rizzo has much to be proud ofMike Rizzo has much to be proud ofMike Rizzo has much to be proud ofMike Rizzo has much to be proud of
One of our Mentors, Clem McKown, created a PowerPoint in regards to drive trains models and it may help you with which drive train to choose.
http://wiki.team1640.com/images/b/b0/Drive_Lesson_3.pdf
Unread 20-01-2011, 19:15
Chris is me's Avatar
AKA: Pinecone
Originally Posted by nckureghian14 View Post
Cons: Lacks ease of maneuverability
Does it now? I've seen hundreds of six wheel drives and they all seemed maneuverable to me.
I'm tired of people essentially saying "since mecanum is more manuverable, 6 wheel drive must be significantly less manuverable". Strafing does not equal manuverability, or vice versa.
Unread 20-01-2011, 19:18
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
...you have no idea of how much i have to fight this...
Unread 20-01-2011, 19:22
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
I'd say 6 wheel rocker. With the rock you don't have to worry about "skipping" during your turns.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 20-01-2011, 19:36
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
I second this idea. 6wd with the center wheel dropped 1/8 of an inch, and if you are using the kit frame the center hole is already dropped 3/16 of an inch.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 24-01-2011, 21:05
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
"Cons: Lacks ease of maneuverability"
We actually did a test, and realized that the 6-wheel drive is actually more maneuverable than the Mecanum.
Unread 24-01-2011, 21:21
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
I will agree with the others: 6 wheel drive.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 24-01-2011, 21:41
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
I would say mechanum because that is what our team is using and it works really well but the 6 wheel has really go maneuverability too if you implement the drive system right.
If you use 2 rubber wheels for friction as the two center most wheels and then you use omni wheels for the front 2 and back 2 then you have great maneuverability and better control. However you aren't as maneuverable as with mechanum.
With the six wheel drive train, you have a better resistance from being pushed. My experience shows that the mechanum can be pushed if you have a weaker but faster gear ratio.
Hope this helps
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 24-01-2011, 21:32
Team 2811's Avatar
AKA: Ian Heffron
Pros and Cons:
4 Wheel Mecanum
Pros: Maneuverability
Cons: Slower
Not true. My team had a four wheel mechanum drive train last year and it was really fast in every direction. However, it is true that going straight is faster than going in a different direction.
So why learn?
  #15   Spotlight this post!
Unread 24-01-2011, 21:51
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: 4 vs 6 wheels (what to choose)
IMO, mechanum is a difficult task in programming during the build season, even for very experienced teams. Stay within your capabilities. Wheels are available through AndyMark, so the mechanical requirements can be met if you have the funds. Use the offseason to develop new systems and concepts. I have been in this fo 16 years, and am still learning. Just my opinion.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
