Go to Post Andy Baker is so awsome, that his presence alone at the competition caused the scoring system to crash....multiple times...at all 8 regionals. - Andy Grady [more]
Unread 21-01-2011, 09:36
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
Rookie Year: 2011
inkspell4 will become famous soon enough
Spike Wireing
What gauge wire is used to connect the spike to the PD(power distribution board)?
We are a new team and if you have any other hints for us please feel free to post them here.
Thank You
Chesapeake Regional : 2013, 2012, 2011
Rookie Year: 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 21-01-2011, 09:47
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: Spike Wireing
<R40> All active PD Board branch circuits shall be wired with appropriately sized wire:
Application Minimum wire size
40A circuit 12 AWG (2.052mm)
30A circuit 14 AWG (1.628mm)
20A circuit 18 AWG (1.024mm)
between the PD Board and the Analog and/or Solenoid
Breakouts if a common power feed is used
18 AWG (1.024mm)
Breakouts if individual power feeds are used
20 AWG (0.8128mm)
between the PD Board and the cRIO-FRC 20 AWG (0.8128mm)
between the PD Board and the radio 20 AWG (0.8128mm)
pneumatic valves 24 AWG (0.5106mm)
The branch circuit may include intermediate elements such as COTS connectors, splices,
COTS flexible/rolling/sliding contacts, and COTS slip rings, as long as the entire electrical
pathway is via appropriately gauged conductors.
Spikes are designed to operate with either a 20A Fuse or 20A Breaker, therefore you would need to use 18 Gauge wire or larger.
I suggest reading section 4 "The Robot" of the Manual before making a another new thread to ask another question.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 21-01-2011, 09:50
inkspell4's Avatar
Rookie Year: 2011
Re: Spike Wireing
Thank you we are trying to hook up everything on a practice board and this will help us to do so without complications
Rookie Year: 2011
Unread 21-01-2011, 10:09
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
Team Role: Coach
Rookie Year: 2007
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Re: Spike Wireing
I would use a circuit breaker in competition, you would like it to be able to recover on the field.
Unread 21-01-2011, 10:46
thefro526's Avatar
Mentor for Hire.
Re: Spike Wireing
This is especially true for the Compressor. You don't want you lose your Pneumatics because you've blown a $0.25 Fuse.
Other than that, I don't believe we've ever blow a Spike Fuse with a Motor, but I'm sure it is possible, so if you've got a few extra 20A breakers it's worth throwing them into the Spike's just for peace of mind.
-Dustin Benedict
Unread 23-01-2011, 10:39
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Spike Wireing
The old compressor will blow a 20 fuse eventually. The new compressor is unknown at this point. In general, all compressors/motors have a high start current. The specified start current on the old compressor is 27 amps while the run current is only 10-12. It is for this reason, that a 20 amp snap action circuit breaker is recommended for replacing the 20 amp fuse in the Spike.
Al
WB9UVJ
www.wildstang.org
