Go to Post We are reluctant to deprive you of the experience of learning how to do your own research. - Alan Anderson [more]
Unread 21-01-2011, 14:29
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
Team Role: Mechanical
2bkrul is an unknown quantity at this point
E-stop bypass?
Is there a way we can bypass the e-stop button using LabVIEW so we can run our robot. We have to order a new button and we would like to run code while we are waiting for the replacement
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
Unread 21-01-2011, 14:31
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
Rookie Year: 2007
captainking is an unknown quantity at this point
Re: E-stop bypass?
go to the "diagnostic tab" iirc, double click on the "stop button" part
Integrity first
Service before self
Excellence in all we do
Unread 21-01-2011, 14:43
Bonzo Bonzo is offline
Master Programmer
AKA: Dillon "Bonzo" Hendrickson
FRC #2977 (SirLancerBots)
Bonzo is an unknown quantity at this point
Send a message via AIM to Bonzo Send a message via MSN to Bonzo
Cool Re: E-stop bypass?
when you double click it, the question of whether you you will be careful or not pops up. just click yes and you will wait about 20-30 seconds for an over ride to occur then go ahead and enable and have fun!
Unread 21-01-2011, 14:44
andreboos andreboos is offline
FRC #3021 (The Agency)
Rookie Year: 2010
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Re: E-stop bypass?
What problems are you having with your old one?
Our old button only registers when we have the wire at a certain angle, give or take a few degrees, so we ordered another last week. Is this a problem that other teams are having too?
Unread 21-01-2011, 15:09
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: E-stop bypass?
Same issue. Something is loose.
Unread 21-01-2011, 15:12
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Rookie Year: 1999
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Re: E-stop bypass?
I think the button just has a couple of screws and may be snapped together as well. You can probably open it up and re-solder the wires. It should be a simple fix - there are only 4 wires for USB 1.1/2.0.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 21-01-2011, 15:18
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: E-stop bypass?
Our stop button was having a similar problem... turns out there was a loose wire in the USB header that plugged into the computer. Snipped the cord, soldered on a new one, and we were good to go.
Unread 22-01-2011, 08:28
2bkrul's Avatar
AKA: Brandon Krul
Re: E-stop bypass?
Same here. The cord is loose by the USB
Team 964 on TBA!
