Go to Post Here we go again with all kinds of speculation. We can never out guess FIRST. - BobC [more]
Unread 21-01-2011, 19:24
spope14 spope14 is offline
Team Mentor 3585
AKA: Scott Pope
FRC #3585 (Rogue Robots)
Rookie Year: 2011
spope14 is a jewel in the roughspope14 is a jewel in the roughspope14 is a jewel in the rough
Wago connectors and block
I am very unfamiliar with how to connect the wires in the terminal block and in the WAGO wire connector ends supplied. I looked at a few things and they said "use the supplied tool", which was not supplied in the kits. Any help nappreciated, I have tried the WAGO site as well.
Unread 21-01-2011, 19:38
sam_who sam_who is offline
FRC #2190
sam_who is an unknown quantity at this point
Re: Wago connectors and block
Use a small flat-head screw driver. So long as the width of the blade is narrower than the slot, you should be okay.
Unread 21-01-2011, 20:20
Team Mentor 3585
AKA: Scott Pope
Rookie Year: 2011
Thank you very much! Made all the difference!
Unread 22-01-2011, 09:01
tuyauxtu tuyauxtu is offline
FRC #0781 (Kinetic Knights Robotics)
Rookie Year: 2010
tuyauxtu is an unknown quantity at this point
I came across this http://www.oregonfirst.org/wp/wp-upl...onics_2009.pdf. On page 21 there is a great picture showing how to "work the wago". Important not to pry (which can result in flying screwdrivers!) but to slide the tip of the screwdriver along the back and down until it holds the wago slot open. Remove screwdriver once the wire is in place, test pull wire to make sure it is locked securely.
