Go to Post You cannot change people, you can only change yourself. - KenWittlief [more]
Unread 21-01-2011, 21:22
mv2112's Avatar
mv2112 mv2112 is offline
Derpologist
AKA: Mike
FRC #3044 (0xBE4)
Rookie Year: 2010
mv2112 is an unknown quantity at this point
CAN + Old Image are not allowing a reimage
When we tryed to reimage our cRIO it says this:
The imaging tool has detected that you have a CAN plugin enabled and you have an old image installed. Your cRIO would hang when trying to reboot. Please remove the CAN plugin from the StartupDlls line in ni-rt.ini and then manually reboot your cRIO before trying again.
How can we fix this???
