Go to Post In my opinion, if it can light a fire in your heart to burn with passion, and you can maintain that fine line between passionate and crazy; then go for it. Power to Passion. - RKElectricalman [more]
Unread 22-01-2011, 00:13
noa_n_f noa_n_f is offline
FRC #1378
noa_n_f is an unknown quantity at this point
Are Limited Slingshots allowed?
One of our ideas to deploy the minibot consists of a surgical tubing assisted slingshot, thereyby extending the minibot past the pole's base. It would include a physical stop, preventing the slingshot from shooting the minibot any more than 18 inches. Do the game rules allow this? I know that slingshots are in a bit of a red zone.
Unread 22-01-2011, 00:21
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Are Limited Slingshots allowed?
I think that if the slingshot was mounted to the hostbot, and purely horizontal, you would be fine.
If the slingshot imparted any vertical motion on the minibot to gain an advantage in the race, or used energy stored on the minibot, you would have issues.
As with anything on Chiefdelphi, this is my unofficial interpretation, which does not hold any water at the inspection station.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 22-01-2011, 02:20
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
I agree with Joe. Under the current rules, most inspectors would take a close look as to safety. Are you preloaded and, if so, is there a fail safe mechanism to prevent premature deployment as your team places the robot onto the field, et cetera.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 22-01-2011, 08:26
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
<G19> is pretty clear about vertical movement - make sure the slingshot doesn't violate that. If you are just talking about horizontally pushing the minibot onto the pole... it's all going to come down to safety. Safety while working on it, safety for the audience, safety for the field crew. The last thing we want is to see a 15lb, pointy metal object airborne.
Unread 22-01-2011, 08:36
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Noa,
All of these answers are correct. Under no circumstances will you be allowed to impart vertical motion on the minibot by anything other than direct action of the FTC motor(s). Stored energy always will garner additional inspection.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 22-01-2011, 23:41
FRC #1378
Thank you all very much for the input. The slingshot will aid purely in horizontal movement.
Unread 23-01-2011, 09:41
Unsung FIRST Hero
Rookie Year: 1996
Noa,
The determination of vertical and horizontal motion on the minibot will be performed by the refs on the field during each match. Inspectors will determine the safety of the stored energy during the inspection process.
Al
WB9UVJ
www.wildstang.org
