Go to Post So, in the good old FIRST spirit, let's all start brainstorming and sharing ideas, ok? :D - LauraN [more]
Unread 01-22-2011, 10:40 AM
mutantblond mutantblond is offline
FRC #2523
mutantblond is an unknown quantity at this point
Using I/O setup on Driver's Station
How do you use the I/O setup on the Driver's Station to set the power profiles in the Line following template file so that the robot follows either the straight or forked path?
thanks,
elaine
team 2523
Unread 01-22-2011, 10:59 AM
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Using I/O setup on Driver's Station
If you click on the driver station IO tab buttons BEFORE activating autonomous mode, then they will work.
Changes to them once you're running in Autonomous won't be sent on to the robot.
Just check the autonomous code for which switches cause what action.
