Go to Post FIRST was the best thing that accidentally happened to me. - Stephen Kowski [more]
Unread 22-01-2011, 10:48
Tommithy Tommithy is offline
FRC #2410
Tommithy is an unknown quantity at this point
Thrower
This is our first year using C++ for programming, and does anyone have any idea on how to program the thrower.
BLARG!!!
Unread 22-01-2011, 11:31
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Thrower
How does your thrower work?
Does it use motors? Pneumatics? Oldmatics? (that was a joke.)
Is it controlled with a Spike, Victor, Jaguar? If it is a Jaguar, is it using CAN or PWM?
Unread 22-01-2011, 12:21
FRC #2410
Re: Thrower
uhh build team says they are using an Electric Winch
BLARG!!!
Unread 22-01-2011, 12:54
FRC #2410
Re: Thrower
Jaguar PWM
BLARG!!!
Unread 22-01-2011, 12:56
FRC #2410
Re: Thrower
Jaguar
BLARG!!!
Unread 22-01-2011, 12:59
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Re: Thrower
Okay. So you need to declare your jaguars, then set them to drive the winch.
Also, this should be moved to the C++ section.
