Go to Post sometimes you have to dig through the trash and clean off the layers of dirt and grime in order to find diamonds in the rough. - Travis Hoffman [more]
Unread 22-01-2011, 18:16
Ethan Spitz Ethan Spitz is offline
President
FRC #3637 (The Daleks)
Team Role: Leadership
Rookie Year: 2011
Ethan Spitz is an unknown quantity at this point
Switching from Autonomous to Tele-op
We are having problems getting the driver station to run through autonomous then tele-op. If we start up in practice, it runs our autonomous code, then stops, then starts tele-op. Only thing is that the autonomous code does not stop. the wheels continue to turn and tele op has no motor control. solenoids, servos and the compressor all turn on.
Does anyone know how to fix this?
Ethan
Edit Attached is our Autonomous code, everything is running under robot main.vi
Name:	Build 1-20-11 1.jpg
