Go to Post The very fact that parts are rumored to be being re-used may be sufficient reason for the rule-makers to change a rule to prevent the re-use of that very part (not that they would ever be that devious!) - dlavery [more]
Unread 22-01-2011, 18:20
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
Rookie Year: 2010
MAldridge will become famous soon enoughMAldridge will become famous soon enough
jaguar scaling factors
My team (3247) just got our bot driving today and we noticed a big problem. With four motors we are using 2 black jags and 2 grey jags. This seemed fine except for a problem where the scaling is not quite right! When driving foward, one side (black side I think) is way faster. As the programer for the team, I was told to fix it. I was thinking that maybe I should attempt to scale the joysticks. The problem with this is that my team also wants to use arcade drive. We used last years DS for testing but they think it will be easier to control with arcade.
My questions are:
  1. How do I make each side move in step so that the bot drives strait using PWM
  2. How do I re-scale the joysticks so that most of the range is for slow speeds and it is still possible to get full speed
  3. Is there a better solution that does not involve buying more jaguar controllers
Thanks in advance
Unread 22-01-2011, 18:57
markgryzwa markgryzwa is offline
FRC #3206 (Royal-T-Wrecks)
Rookie Year: 2010
markgryzwa is on a distinguished road
Re: jaguar scaling factors
Same issue for our team. Would love to hear the answer. The black jaguars output about 12.5V in full on, the grey/tan jaguars are about 10.5V. Quite a difference to balance.
Unread 22-01-2011, 18:59
Us3rNam3's Avatar
Us3rNam3 Us3rNam3 is offline
Is LabVIEW code lighter than C++?
AKA: Tristan
FRC #1625 (Winnovation)
Us3rNam3 is an unknown quantity at this point
idk if this would help any but you could always try installing encoders onto each side of the drive train then using those output values and then scaling back each motors output.
DFTBA. NERDFIGHTERIA FOREVER!
J'adore les robo.
Unread 24-01-2011, 10:53
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
Rookie Year: 2007
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
I don't want to move this thread in a different direction, but could you please elaborate on how you measured the output voltage?
Did you use a volt meter, scope, other?
Were motors connected to the outputs?
Did you take these measurements at the same time (measure one, then the other, same setup)?
-David
Unread 25-01-2011, 10:17
Rookie Year: 2010
I assumed the duty cycle at full on was 100% so I simply used a voltmeter
Set to DC. No motors. No load.
Measured two Black and two Grey
Full forward and full reverse
Same result consistently.
Unread 25-01-2011, 10:24
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
This is a false measurment. The Gray Jags at full really drop maybe .15v more than the Black Jag.
Your measurement was just a by-product of the Gray Jaguar circuit design.
It doesn't measure properly without a load.
The Black Jaguar has a different design that doesn't affect no-load measurements.
I tripped over that myself earlier, although you have to read several surrounding posts to understand what was going on in that thread.
I liked Eric's way of putting it...
Originally Posted by EricVanWyk View Post
Put simply, it would be physically impossible for a Jaguar (or a Victor) to have an actual 2V drop while driving a motor and not be on fire: It is WAY too much heat to dissipate.
Unread 25-01-2011, 10:52
patrick_allen patrick_allen is offline
patrick_allen is an unknown quantity at this point
What about creating a slider "trim" control.
Your "trim" control would run joystick position through a multiplier on one set of Jags. Experiment with trim position until you're satisfied that you're driving in a straight line.
This method will only be suitable if the differences between the Jags are consistent at various speeds.
Unread 25-01-2011, 10:59
Rookie Year: 2010
Thanks Mark.
We do clearly have a small speed difference between black and grey as well. Much harder to measure though.
I'll measure under load and see what I get.
Unread 25-01-2011, 19:40
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
Rookie Year: 2010
I don't think the offset is linear. I just tried my code today with the speed being divided by two and the robot drives much straighter. I haven't had a chance to test PID yet. Electronics guys are still trying to get encoders connected.
Unread 26-01-2011, 07:38
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I should have mentioned this much earlier. How much wire do you have feeding the two sides of the robot? A frequent problem is inches feeding one side of the robot with feet feeding the other side. If you are using #12 to feed the drive system, you can accumulate significant loss in the wiring. It amounts to about 0.2 volts per foot at near stall current for CIM motors. Remember you have to count both the black and red wires to arrive at the correct calculation. It is for this reason that I recommend a central location for the PD to balance the wiring.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 26-01-2011, 13:44
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
Rookie Year: 2010
all wiring runs follow the same path, we had the problem you are describing last year
Unread 22-01-2011, 19:46
Just Itinerant
By far the simpler solution would be to pair a Black Jaguar with a Gray Jaguar on each side, rather than having all Blacks on one side and all Gray's on the other.
You can certainly scale back the faster side permanently by multiplying the joystick input to just the Black side by a factor or by using encoder feedback and PID.
Unread 22-01-2011, 20:09
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
Rookie Year: 2010
because these are the CIMple gearboxes from andymark, I don't think it would be advisable to mix controllers. I see ground gears for anyone who tries that...
The voltage data is very helpful, does anyone know if the speed is ramped in a linear fashion? If it is linear, then it would be some very simple math to make them even.
Unread 23-01-2011, 00:51
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
I would suggest using PID with encoders to get a closed-loop control.
There's nothing quite like feedback for repeatability and low-speed handling.
-- Marshal Horn
  #15   Spotlight this post!
Unread 23-01-2011, 12:14
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
Rookie Year: 2010
Can you suggest any good resources for creating PID algorithms? I am used to text based languages on OS/2 so any resources that are labview based would be nice.
