Go to Post In my opinion, watching someone CAD is about as exciting as watching them sleep. - DampRobot [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 22-01-2011, 18:35
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Jaguars intermittently disconnecting
Hi all,
I just updated our 2010 cRIO to the 2011 image and rebuilt the code against the 2011 libraries. After switching the jaguar code to the new WPILib version though, we are having some major issues. Jaguars have been updated to v92, and we are using a serial bridge.
When the code is enabled, at random intervals 1 or more motors stop for a few seconds, then continue moving again. On the jaguar when the motor stops the status LED is flashing yellow, when it is working it is the expected state. I've reduced the code down to just joystick input and output to the 4 jaguars with no change. I haven't seen it die though when using only two jaguars. Even when idle the status LEDs on the jaguars show the same symptoms. NetConsole gives no errors, MotorSafety has been disabled on all of the jaguars, and it works fine in BDC-COMM.
Any help would be appreciated
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
