Go to Post If you let me borrow your time machine, there are various ways to fix this. But mine is on the fritz. - Greg McKaskle [more]
Unread 22-01-2011, 19:09
Sandvich's Avatar
Sandvich Sandvich is offline
NOM NOM NOM
AKA: Kyle
FRC #0696 (The Circuit Breakers)
Team Role: Mechanical
Rookie Year: 2011
Sandvich is on a distinguished road
Pneumatics Question
Do you have to have one solenoid for each actuator, or can you have one solenoid controlling multiple actuators?
Unread 22-01-2011, 19:14
2611.Shooter 2611.Shooter is offline
Programmer
AKA: Andrew Lavery
FRC #2611 (Vectors)
2611.Shooter is infamous around these parts2611.Shooter is infamous around these parts
Re: Pneumatics Question
while you can not have more than one solenoid powering a acuator, the rules do not prohibit multiple acuatorss per solenoid, as far as I can tell. However, this will slow down each of your acuators, as the flow rate will be restricted. Why do you want to do this?
Unread 22-01-2011, 19:41
Sandvich's Avatar
NOM NOM NOM
AKA: Kyle
Rookie Year: 2011
Why would the flow rate be restricted? All that is being changed is that the air flow is being split after going through the solenoid instead of before. If we did this we could save a solenoid.
Unread 22-01-2011, 19:46
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You're trying to move twice the air through the same opening. That's going to have an effect; your actuation will be slowed down somewhat, as only so much air can get through at the same time, and you have the same pressure to push air through with. For, say, a 3/4" bore/1" stroke cylinder, like might be used for shifting, that effect would be negligible. But when you get to more of a 1/5" bore, 12" cylinder, say, there will be a noticeable effect on speed.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 22-01-2011, 19:56
Sandvich's Avatar
NOM NOM NOM
AKA: Kyle
Rookie Year: 2011
The actuators are the 3/4 x 3/4" cylinders used for the Andy Mark supershifter. So if the effect is negligible, using one solenoid would be okay?
Unread 22-01-2011, 20:05
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Probably. The reason it's negligible (or close to it) is that you have a fairly small volume of air to move, and small volumes tend to move faster than large ones in this type of case.
Past teams:
Unread 22-01-2011, 20:07
Sandvich's Avatar
NOM NOM NOM
AKA: Kyle
Rookie Year: 2011
OK, thanks.
Unread 22-01-2011, 20:14
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
For many applications, it makes sense to use one solenoid instead of 2.
Shifting is one example - it is important that both transmisssions shift at the same time. So having a single solenoid controlling the shift ensures that both will be energized together. If you have separate solenoids, and one sticks or fails (bad connector, bad signal, etc.) you can end up with one side of the robot in hi and one in low.
Other examples could be any system where it is important that both cylinders (or more) be in the same condition.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
