Banebots gear boxes in CAD?
Does any one have banebots gearboxes in CAD? (for the RS-550's or RS-775's)
Re: Banebots gear boxes in CAD?
If you're talking about the P60s, there's a couple of models on 3dcontentecentral:
http://www.3dcontentcentral.com/down...=171&id=208143 http://www.3dcontentcentral.com/down...=171&id=171413 The only difference between the reductions is the lengths, which you can from this datasheet: http://banebots.com/docs/P60A-DATASHEET.pdf In Autodesk Inventor, you can use Thicken/Offset to make the necessary changes, not sure what the appropriate tool would be in other packages. --Ryan |
