"It's the Claaaawww"........ prototype.
Here are a couple of quick clips or our prototype claw. The final will be much lighter and the action will be faster. The beauty of prototyping it is we found some very interesting mods that really make it work well.
http://www.youtube.com/watch?v=QMjZ1swhchc http://www.youtube.com/watch?v=wMU7VPON7M4 |
Re: "It's the Claaaawww"........ prototype.
That's a super nice prototype. Good enough to be the real thing.
But there is a little problem. One of our team "rules" is: No wood on the robot!! Some rules are made to be broken. ![]() |
That looks awesome actually. Fantastic work by you and your team! Are you planning on making the final version out of aluminum or polycarbonate?
Yes. The fingers will be polycarbonate and the linkages will be aluminum.
she's a looker, thats for sure. For some reason a lot of robots this year look awefully violent...it's awesome.
neat prototype!
We have a rule: We make no rules about what materials we can use, the GDC does that for us. Our 2009 robot was made mostly of plywood and plastic pipe, and it was the most effective robot we have made. It even had a couple wood 2x4s in it! Our prototype has two pieces of plywood also, but they work differently. We used a pneumatic, outside, single point grabber in 2007 and were not real pleased with it, even after a redesign between regionals. We're going for the inside grab this year, wish us luck! and when we get it actually grabbing a game piece under computer control, we'll put video up. |
There were two problems. We did not anticipate how variable the tube inflation would be, and the claw just did not get a good enough grip on tubes that were a bit soft. The second problem was that the tubes could move sideways, they did not want to stay properly oriented.
I think the inside claw will help with both of these problems. This year the goal pegs have a much smaller end cap, so the tube placement action will be different, and more appropriate for an inside grabbing claw. For the original poster, I suggest you have the students try to shake the tube off the claw by moving the "arm" sideways as if it were on the robot, and the robot were maneuvering as robots do in real games. See if you can hold onto the tube, and that the tube does not move around too much. It could be that this design does work just fine. |
#10
If I recall correctly, both 47 and 33 had "inside grippers," with Chief Delphi using a bucket cut in half as part of their end effector.
