Code built, robot somewhat connect.. but not running.. HELP!
So, today our team put a entire labview code together and a prototype of the robot and everything on it we'll be using.. good there.
We'll.. we go to hook it up and it wont connect wirelessly.. we'll check the bridge and router monday.. so now.. we do it by wire.. working great.. connected and everything.. deploy the code after building and were good to go.. turn on the robot.. it connects.. runs.. but.. push the joysticks.. WONT GOOO! I forgot to take note of the driver station errors in the diagnostics.. anyone having this problem and find a solution? we also tried code examples from labview.. help us :/ we are imaged to the new v25 image <edit> i found a few other things to fix in our code.. but anyone else still have any thoughts? </edit> |
Re: Code built, robot somewhat connect.. but not running.. HELP!
You don't mention much about the driver station. Is your robot enabled? There may be DS issues that need to be resolved before you can enable. The other issue could be errors in Begin or in Teleop that are cause your motor updates to return an error.
Greg McKaskle |
i need help on finding the set speed control in the while loop thing i can not find it at all
Look under the diagnostics tab, and if it doesn't show anything there, it's probably wiring. If there's something there, by all means post it!
