Re: necessary torque for an arm
Originally Posted by 548swimmer
This is assuming a 10 lb manipulator approximately five feet away from the closest pivot point on our four-bar linkage.
10 lbs isn't bad considering that. Is that including the weight of the arm itself? or is that just the actual manipulator on the end? If your considering the weight of just the manipulator, your numbers are going to be a bit low. If your considering the weight of the arm too and are placing it at the end, they will be a bit high. You should be placing the weight of the arm at the midpoint of the arm and it should give a pretty good approximation. There will be a bit of error because of various things, but you should be pretty close.
PS: I'm intrigued by the thought of a 5 foot long manipulator.
EDIT: Also, don't forget rotational inertia. Its easy to focus on gravity being your resistance that is fighting you, but it isn't the only one. You also need to consider rotational inertia. You should be able to do some research on it, but if you continue to have problems after that...give me a PM and I'll help you through the math.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
