Go to Post I think being successful in FIRST is creating an environment where people can grow, learn, change, and recreate... It's about making an environment where kids feel they can be successful... in whatever discipline they choose. - ColleenShaver [more]
Unread 23-01-2011, 20:38
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Maneuverability
Regardless of the type of drive train, what determines a robot's maneuverability?Is it the speed, traction, acceleration or something else? I made the PWM output an exponential function and I currently capped the max PWM output of the robot at around 50% of the full capacity. So it goes really slow at the beginning and faster at the end. Everyone pretty much says that the handling is great, but we are only maxing out at around 9.3 f/s. Is that just hurting ourselves by having a slower bot? Is there any other way to have great handling of the bot without sacrificing speed?
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 23-01-2011, 20:44
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: Maneuverability
Teach your drivers how to drive the robot at a higher speed?
Realistically, a robots maneuverability is a product of all of the things you listed above. Without knowing more about the specifics of the drive-train it's relatively difficult to tell you what will help aside from more practice.
Though, using the information you've given, I'd imagine that you could program the robot in such a way that it would normally max out around 50% signal (9.3FPS) then at the push of a button or flick of a switch the driver would have access to the full speed of the drive.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 23-01-2011, 20:50
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Maneuverability
Just like Dustin said, all of those things you said are components of maneuverability. Speed, defiantly, the accuracy of the turning of the robot (Like how easily you can go from one orientation to another without having to re-adjust), and what I believe is most important, the amount of practice the drivers have.
I am sure that there are some ways that are better than others to make the robot maneuver better by programming or changes in design, but if it takes time out of driver practice, I would not recommended it.
Good luck in 2011!
Unread 24-01-2011, 09:30
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Re: Maneuverability
Using an exponential function is a great idea but I would not reccomend capping the max speed. Try to derive a new exponential function that gives you the control at low Joystick values that you want (this will help position the robot to place the tube) but still lets you have the top speed for straight line driving (like back to the feeder slot)
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 24-01-2011, 13:12
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: Maneuverability
We caught ourselves using this term "maneuverability" without defining it as well. We got caught up saying we want a maneuverable robot.
What is maneuverability? We defined it as being able to translate in both the x and y directions and rotating about some z axis (CG of robot). This is becasue you can have a fast velocity or great traction, but that does not mean you are maneuverable.
It was a very weird discussion we had...
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 24-01-2011, 15:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Maneuverability
The "what does maneuverable mean" discussion happens every year when the TechnoKats are selecting a robot design. I think we've settled on a general definition of "the driver can make the robot go in the desired direction".
Unread 24-01-2011, 15:12
Chris is me's Avatar
AKA: Pinecone
Re: Maneuverability
Maneuverability defined as "strafing" is seriously limiting your mindset and point of view.
That said, I've heard good things about square or cubic functions - usually you'll want your speed to pick up a lot in the last half or third of your joystick's travel.
Keep in mind more limits your robot's speed than controllability.
Unread 24-01-2011, 15:20
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
Re: Maneuverability
Maneuverability will be key in this year's game. Unlike last year, there's no bumps to get over or tunnels. Nevertheless, you are still going to want a robot that get around the field efficiently, especially since you have to get the tubes from the other side of the field and bring it back. THat being said, you will want peed, but not so fast that you cannot control the robot or being too light and easily tipped over. If you are going to go with more speed, lower your center of gravity and distribute the weight evenly. As for handling, make sure your robot can turn efficiently and easily, and make sure your drivers know what to do in all types of situations and how to get out of them. good luck!
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
