Go to Post But here's the beautiful thing about FIRST: you are supposed to make mistakes. - RunawayEngineer [more]
Unread 23-01-2011, 23:17
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Question Errors
Ok, here's a question... Our team is using two robots right now, one for prototyping, and the other one for our drive team to use for practicing driving.
The proto-typing robot uses arcade drive with two motors, while the practice bot uses mecanum. When ever we drive/use either one of these bots we consistently get an error close to something like this... "The loop containing RobotDrive is not running fast enough..." (the actual error message is longer but I cant remember all of it).
I have no clue what is causing this error and I get it even if there is only drive code in the program... is anyone else getting this error? Does anyone know how to fix it?
- Thanks in advance!
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 23-01-2011, 23:51
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Re: Errors
I'm pretty sure that that is this year's equivalent to the watchdog, so try speeding up the loop somehow.
If you still can't get it to work, try having the vi to run the motors in periodic tasks and have all the joystick processing in teleop and use global variables.
Unread 24-01-2011, 07:33
Re: Errors
Before changing the code, determine how long between subsequent calls to update the motors. You can do this with a millisecs and a feedback node, or you may be able locate a subVI called Loop Timing and place that near the motor updates.
According to the Safety manager, you are updating the motor setpoints pretty slowly. Determine why and resolve that issue.
If you are having trouble tracking down the slow code, you may also want to turn on the profiler and run your app.
Greg McKaskle
Unread 24-01-2011, 08:13
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
Re: Errors
Thank you both for replying quickly! . I have tried to look for the loop that the error seems to be referring to, but I can never find it. But, I will look again!
I'm still curious as to how many other people are getting this error, because it happens to us even if we use the default code.
Unread 24-01-2011, 10:31
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Errors
By "RobotDrive" it is referring to anything that uses the motors opened with "Open 2 Motors" or "Open 4 Motors."
That just means anywhere you use the Arcade Drive, Tank Drive, or Holonomic Drive vis.
Unread 24-01-2011, 11:33
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
Re: Errors
Thanks Mark!
