Go to Post Most importantly, get some sleep. - Libby K [more]
Unread 23-01-2011, 23:21
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
articulating arm help
We are making an articulating arm for our robot. we have a cim motor on a CIMple gearbox with a gear chained to a much larger gear which is connected to the arm itself.
our problem comes when we are running the arm. we would like to be able to move the arm to any spot we want and have it stay there when we let go of the joystick. currently when we let go of the joystick, gravity takes over and the arm falls down. I'm asking if there is a way to keep it in any place we stop at. do we use a brake to create resistance or do we use encoders? if we have to use encoders we would need help in figuring out what our distance per count is among other settings in the programming side of things.
Unread 23-01-2011, 23:33
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Re: articulating arm help
Mechanical things that can help include (a) a cantilever, (b) a spring or other tension device to aid in lift, and/or (c) a screw drive instead of a sprocket drive.
As for code for encoders -- sorry, I'm useless on that count!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 23-01-2011, 23:36
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
FRC #0862 (Lightning Robotics)
quinxorin will become famous soon enough
There are several ways to solve your backdrive problem (that's what it's called)
The mechanical solution, guaranteed to work, would be to replace your CIMple box with a wormgear. It cannot be backdriven. This is the same type of gearbox as comes preinstalled on the window motors.
A simple software solution would be to switch the jaguar controlling your CIM from coast mode to brake mode. This is likely to be not 100% successful, however.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 25-01-2011, 23:19
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Worm gears can backdrive, although depending on the angle of the teeth on the worm, the gear material, and whether it was lubricated or not, the torque required to backdrive the worm gear may exceed what the teeth of the gears can withstand. Thus, for a limited range of torque, worm gears can be considered non-backdrivable.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
A simple mechanical solution to this problem is to add a "counterweight", or something similar, to balance out the weight of the arm. Many teams have used gas springs in the past to do this, example here. Latex tubing could also be implemented as a spring to counteract the weight of the arm and would likely be cheaper.
Unread 24-01-2011, 00:31
Da Kid's Avatar
FRC #2957
how do you switch the jaguar to brake mode? does it have to do with one of the jumpers?
Unread 24-01-2011, 00:43
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Yes, it has to do with one of the jumpers. It should be documented in the Jaguar docs.
To solve this in software, you would attach an encoder to one of the shafts and then use a PID loop to control it. There are a couple of papers in CD-Media about how to tune one and what one is. A PID loop can be thought of as attaching a software spring to the arm to help hold it up in position. The P term is probably enough to at least get you started, and is easier to understand than the rest of them when you are first starting out.
Unread 24-01-2011, 00:44
Astarties's Avatar
Astarties Astarties is offline
Evil Robot Overlord
FRC #2057 (AV Cyber Bulls)
Rookie Year: 2007
Astarties is on a distinguished road
I would use one of the window motors included in the KoP. They're intended for this sort of thing. They have a screw drive gear box on them, so they're a little slow, but they have crazy torque and can hold a position with a load on it.
"Stand tall and shake the heavens!"
"Never tell people how to do things. Tell them what to do, and they will surprise you with their ingenuity." - General George Smith Patton, Jr.
By the prickling of my thumbs, something wicked, this way comes. Open Locks, whoever knocks!
"Never hold discussions with the monkey when the organ grinder is in the room."- Winston Churchill
Unread 24-01-2011, 00:58
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
what is brake mode?
Spartans, Prepare for GLORY!
Unread 24-01-2011, 02:21
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Originally Posted by bobosalad View Post
what is brake mode?
Bob,
A DC motor converts electrical power to mechanical power. If you remove the input voltage and spin the mechanical side, the motor becomes a generator.
As a generator, if the electrical terminals are open, there is no current and the "drag" of the motor on the mechanical system is at a minimum (just the frictional losses are felt).
However, if you short the electrical input leads to the motor, it generates electrical current from the mechanical system. This requires that the mechanical system to do more work hence, the motor resists the rotation.
So, for either the Jaguar or the Victor, if the brake/coast jumper is set to "coast" the motor offers the least mechanical resistance that it can when commanded to no speed. Likewise, In the "brake" position, the speed controller will offer the greatest mechanical resistance to rotation when off.
Hope this helps.
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 24-01-2011, 02:51
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
You may wish to consider using the jaguars for your arm... they can take a feedback circuit from a potentiometer at the joint and then (using settings that you provide) attempt to provide sufficient power to the motor to move to and hold the position that you want.
Alternatively, labview offers a similar PID routine to control arm position. You're looking for a "closed loop feedback" system, where your driver is entering the arm position data and leaving it up to the robot (either the cRio or the Jag) to figure out how to achieve that position.
Note that this requires using the CAN bus... not the PWM cables.
Note also that this is the second step towards a solution... the first, as advocated earlier, is attempting to counterbalance the "dead weight" of the arm with springs or counterweights.
Jason
P.S. Unless your arm joint is exceeding the range of a potentiometer (usually around 270 or so degrees), I'd recommend using a pot rather than an encoder. It is simpler to just read an analog input than to zero and track an encoder.
Unread 24-01-2011, 17:02
Da Kid's Avatar
FRC #2957
our team has never used pid or CAN. do you know where some resources are for us as far as programming with pid and CAN and connecting the Jaguars via CAN?
Unread 25-01-2011, 11:22
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
Team Role: Leadership
Rookie Year: 2010
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
About the window motors, I was told that the screw drive in them does not allow for back driving. and aren't they far too slow to be effective if reaching the top rack? just wondering plus the thermal lock on them could be a problem...
"Though I fly through the Valley of Death I shall fear no evil, for I am at 80,000 feet and climbing."
Unread 25-01-2011, 11:38
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you intend to use the motor alone to hold the arm up, without any mechanical counterweight or spring-loading, be cautious. You'll be running the motor at or near stall a lot of the time. A CIM can handle that for a while, but it will get very warm and you might want to consider a way to cool it off during or between matches.
A Fisher-Price or Banebots motor will not handle that kind of abuse well at all. They rely on an internal fan to keep their windings cool, and if they're not turning, neither is the fan. You'll melt something in short order, followed by smoke. Nearby veterans will sniff the air and nod at the familiar smell of a fried motor.
  #15   Spotlight this post!
Unread 25-01-2011, 13:23
HarveyAce's Avatar
FRC #3329 (CAMBots)
Rookie Year: 2010
Well thats not good then. We were going to use a Banebots motor hooked up to last year's gearbox with a chain to power our four-bar shoulder joint. we were going to power the robot drive with the four cim motors, but is that necessary? should we just use two there and use a cim to power the arm?
