Go to Post Let's just say that I am old enough to... - dlavery [more]
Unread 24-01-2011, 16:47
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
4 motors with 2 vs 4 CIMple gearboxes
We are planning on doing a 4 wheel drive bot, however
would 4 CIMple gearboxes with one CIM in each be better then just running 2 CIMple gear boxes with 2 motors each?
I would assume the power output would be the same? but not a 100% sure.
Any input would be helpful.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 24-01-2011, 17:22
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 4 motors with 2 vs 4 CIMple gearboxes
4 gearboxes has 4 times (gearbox friction and losses).
4 gearboxes also has 4 times (gearbox weight).
They also take up more space.
But you might get away without needing any chains to drive the 'other' wheels (= less weight).
Think for yourself the advantages and disadvantages then discuss it with a mentor. Only you can decide what's best
Unread 24-01-2011, 17:25
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: 4 motors with 2 vs 4 CIMple gearboxes
The first thing you should think about with 4 whl drive is that the robot will turn with difficulty. Have you tried it on carpet with the kitbot parts? Not the same as driving on a slick tiled floor or hardwood gym floor.
In addition, powering drive wheels independently works until the robot lifts in a pushing match. Then less power is transferred to the carpet. You will probably be better off (more competitive) if you use dual CIMS to each side. Do a search for 6 whl drive on this site. There's tons of info on this topic.
In addition, AndyMark and Banebots have dual CIM transmissions available, saving weight from a four transmission setup.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 24-01-2011, 21:14
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
Well for having one gearbox with 2 CIMs on each side, we would need to run longer chains. Would having the longer chains have problems falling off in competition?
So running one gear box each side would give more pushing power then running one gear box on each side?
Unread 24-01-2011, 21:31
Hodge1
Rookie Year: 1996
One gearbox with 2 CIMs on each side would, overall, deliver more power to the wheel(s) still in contact with the carpet. However, traction then will come into play.
If you're using #35 chain, it is more forgiving. Allow for chain tensioning as well, and be certain your drive and wheel sprockets are aligned. Some teams use #25 chain, and wheel alignment and chain tensioning are much more critical to minimize potential chain walk off from a hard hit from the side.
Sweat the details
Unread 24-01-2011, 21:46
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
Thank you for the replies, i think we might just go with 2 gear boxes and 4 CIMs.
I assume #35 comes in the kit?
Unread 24-01-2011, 21:59
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Chains shouldn't be a problem as long as they are tight enough and they are VERTICAL! I can not stress enough how utterly impossible it is to use long horizontal chains, as we bent our sprocket shafts last year trying to get the chain tight enough to counteract gravity tendency to pop the chain off(ultimately permanently disabling our robot). As long as you have the room chains will work (Even though i mortally despise chain now)
Unread 25-01-2011, 16:57
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
Thanks for all your input
Now we just need to finalize everything
Decisions Decisions Decisions...
