Go to Post FIRST was the best thing that accidentally happened to me. - Stephen Kowski [more]
Unread 01-24-2011, 05:27 PM
unionylibertad's Avatar
unionylibertad unionylibertad is offline
unionylibertad is an unknown quantity at this point
other robotics competitions similar to FRC
ive seen a lot of VEX- (eg BEST, botball) sized comps, but nothing on the scale of FRC
is there anything else similar to FRC anywhere?
Unread 01-24-2011, 05:36 PM
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: other robotics competitions similar to FRC
http://robots.net/rcfaq.html
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 01-24-2011, 05:41 PM
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
This thread should provide the information you need.
Unread 01-24-2011, 05:47 PM
Dracon Phinex's Avatar
Dracon Phinex Dracon Phinex is offline
AKA: Daniel Wright
FRC #3130 (ERRORs)
Team Role: Team Spirit / Cheering
Rookie Year: 2010
Dracon Phinex is an unknown quantity at this point
Lightbulb Re: other robotics competitions similar to FRC
Isn't there FTC and FLL?
Unread 01-24-2011, 05:53 PM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Not in terms of size and scale. FRC robots are file-cabinet sized or so. FTC and FLL robots fit into file cabinets rather easily.
Collegiate FIRST should be kind of similar to FRC in terms of scale and complexity, when it gets going. Not quite sure about sheer size, but then again flying devices need to be smallish if they're for indoor use.
Oh, and there's always Battlebots. (AKA the #1 most common point of reference for the uninitiated.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
