Labview Help
I have successfully downloaded Labview from the KOP on to the classmate.
I am trying to use that same disc to install Labview on my home desktop for programming purposes. For some reason, the serial number from the KOP won't work on this computer, even though this Labview version should work across multiple computers. Please Help! |
Re: Labview Help
have you been able to successfully install labview (and just not activate it)? you can try installing it without a serial number in evaluation mode (works for 30 days) and then try to activate it.
Re: Labview Help
Yes, I have tried that, but i want to activate it so i can use it past the standard 30 days. I can't figure it out
Re: Labview Help
what I was trying to get at was weather or not your problem was with the LabVIEW install process or activation process.
Re: Labview Help
contact a NI representative. it should work on multiple computers.. I know our team has it on 5 or 6 right now.
Re: Labview Help
My problem is with the activation part. I am trying it again as i am typing right now, so i will see what happens. If it doesn't work, then i will probably contact NI.
