Go to Post Curse those filthy wrench-swinging rivet-popping screw-driving hammer-smashing mechanical barbarians. Hand over the robot to the programmers! - cjl2625 [more]
Unread 25-01-2011, 10:59
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
PID Loop Question
So, I've worked with PID Loops before, although I've never got them working well. I'm wondering a few things:
1. What's the best tuning method? It's especially difficult to tune when you are tuning your drive wheels with encoders to go a specific speed.
2. As far as I know, if I tune free running wheels, the PID values won't work when the wheels are on the ground. Is this true? I have a calculus background, which supports this idea, but I want to confirm with you guys.
3. Is it worth using PID loops on drive wheels?
Thanks!
Unread 25-01-2011, 11:12
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: PID Loop Question
I've never tried closed-loop control of wheel speed. My use of PID for drive motors has always been position control for autonomous driving (and once for "hold position" mode when commanded by the driver). For tuning it, I set up a way to force the robot to drive a specified distance forward or backward on command, then tweaked the P and D parameters until it was repeatable within a tolerable error.
The "inertial load" on the wheels will change drastically when you put the robot down or pick it up off the floor. This will greatly change the D parameter for good tuning, and it is likely to have a significant effect on P as well, making the I parameter very important to compensate for small steady-state position errors. But for speed control instead of position control, you probably don't need to care about I.
Unread 25-01-2011, 12:51
Jogo Jogo is offline
FRC #0353 (Pobots)
Rookie Year: 2007
Jogo is on a distinguished road
@Alan
I've heard twice before that for closed loop wheel speed control, PD is sufficient. What makes the "D" term more valuable than the "I" term in this case?
Unread 25-01-2011, 12:53
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
For the sake of this discussion, I'm going to assume that your sensor input to the PID loop is velocity, and your output is either PWM or voltage.
Are you sure about that? If you want to go at, say 1 m/s, with just a P (or PD) controller, that will take a signal to the motor controller. That signal will only be produced by a PD controller if there is an error, which means you aren't driving at the correct speed. This isn't caused by friction, which is the reason why you added the I term in a position loop.
For velocity control, you really only need P and I. P will act like the D term would in a standard PID position loop. I will act like the P term would in a standard PID position loop.
Unread 25-01-2011, 14:34
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Quite the contrary! In order to achieve perfect tracking in steady state in speed control, it is imperative that integral control is used - when considering position control, there's no need for it, except if deadzone compensation is of interest.
This is explained by the internal model principle: the unstable modes of the reference signal must be included in the loop in order to achieve perfect tracking; a step change's Laplace transform is 1/s (an unstable pole at the origin), so we must include this pole in the loop. A position control system already has a pole at the origin (because position is speed integrated over time), so there's no need for integral control. That isn't true for a speed control system, which is why we must add integral control to cancel the unstable mode of the reference signal. If you were using a sine source as the reference things would be different, of course.
More info than you'd ever like to know (in a seminal academical paper, though): http://www.sciencedirect.com/science...search type=a
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
Unread 25-01-2011, 15:06
Software Architect
I apologize for giving bad advice. I have always used PD control for motor speed when experimenting, but I failed to describe the important step of post-integrating the PID output. When I've played with it, I have used the output of the PID controller as a delta, to increase or decrease the motor control. If I were to use it as an absolute motor power command, which I suppose most people would do as a matter of course, it would definitely need the I parameter!
Unread 25-01-2011, 16:16
FRC #0107
Alan, now you've got me curious.
I know there are tons of methods for position tracking, but what method do you use? E.g. what sensors, what algorithms (if you don't mind sharing ) and other such things... because from my experience, accelerometers aren't capable of accurate position tracking, but who knows, I'm hoping someone proves me VERY wrong.
Also, is there a benefit to a speed control PID? I mean, going straight, yes, but wouldn't directional control be easier with a gyro and joystick position?
Basically I'm asking for what all of you use PID loops for, because it's nice to know what's worth the effort in tuning.
Unread 25-01-2011, 17:41
JonA's Avatar
JonA JonA is offline
Embedded Firmware Engineer
no team (Semi-Retired)
JonA has a spectacular aura aboutJonA has a spectacular aura about
Tim Wescott wrote a excellent piece for Embedded Systems Programming back in October 2000 entitled PID without a PhD giving a really detailed but easily approachable explanation of how PID control works as well as tuning a PID controller.
Tuning a system while it is not under load will result in a very poorly tuned system. While it will account for the plant (motor and gears and whatnot) it will not account for the robot's inertia or the friction in the drive.
Have you ever commanded your robot to go straight forward only to have it veer off to one side or another over time? PID can help. Having closed loop control on your robot's wheels will try to make sure all of your wheels are spinning at the rate you commanded (and by extension make sure your robot is doing what you told it to do) and will compensate to provide some disturbance rejection. The feedback can also be used to then calculate the current position and orientation of a robot when dead-reckoning.
"That mecanum guy"
- Woodie Flowers Finalist Award Winner: 2010 Minnesota North Star Regional
- Mentor and Founder of 7 FRC Teams since 2003.
- FRC Regional Competition Score Keeper/Field Power Controller, Robot Inspector, Control System Adviser, Judge
- Co-Founder, Alumni: Milwaukee FIRST Support Organization
- Board Member, Game Design Committee, Judge, MVP-FTA: Midwest Vex Programs
- Computer Engineering Alumni '06: MSOE
- Embedded Firmware Engineer: Rockwell Automation
Last edited by JonA : 25-01-2011 at 17:47. Reason: Added futher detail in answering questions
Unread 25-01-2011, 18:47
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
...When I've played with it, I have used the output of the PID controller as a delta, to increase or decrease the motor control...
Thats actually a pretty cool learning experience!
If I am understanding you correctly, you were essentially integrating the output of a PD controller, which would effectively give you a PI controller?
Integrated once, P becomes I, D becomes P, so PD = IP = PI?
I'm wondering if there are any useful side effects to this method... I'll ponder it more when I'm not on drugs (lousy cold!)
Unread 25-01-2011, 23:13
Software Architect
Yep, that's apparently what's going on. It explains why I've been improperly suggesting PD control where pretty much everyone else uses PI.
I toyed with closed-loop speed control back in the IFI controller days, when debugging wasn't quite as easy as probing LabVIEW wires or opening a front panel window. I was using a servo as an analog indicator to show me what the PID computation was producing as its output, and I wanted a consistent zero point.
Unread 26-01-2011, 12:43
FRC #0107
Is it safe to assume that 4 wheels on a mecanum base will need the same PID values for speed control?
Unread 26-01-2011, 13:16
Rookie Year: 1999
If your weight is fairly evenly distributed, yes. If not, it will probably still work, but you can do a little better by tuning one loop for the heavier side, and one loop for the lighter side.
Unread 26-01-2011, 13:22
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
If there is a theoretical basis for this belief would you share it please?
Unread 26-01-2011, 13:37
Ether's Avatar
Rookie Year: 1969
I'll take a crack at answering my own question.
If the center of mass is not equidistant from all four wheels, then during conditions of acceleration the wheel(s) to which the CoM is closest will see a greater effective inertia. If there is no (or minimal) acceleration, the only effect would be an increase in rolling resistance which may or may not be significant depending on the flooring material and the wheels.
  #15   Spotlight this post!
Unread 26-01-2011, 14:04
Rookie Year: 1999
Sounds like a nice explanation. In addition, if you are at the traction limit, the wheels with more normal force on them will be able to contribute more to the acceleration of the robot, and should have a more aggressive controller to do that.
