Go to Post Along with having good manners, having good judgement goes a long way in life. - ebarker [more]
Unread 25-01-2011, 16:52
Paul Rodi Paul Rodi is offline
FRC #0975
Paul Rodi is an unknown quantity at this point
Rookie team: How do we set up our cRIO?
This is our first year in FIRST and we can't figure out how to set up our cRIO. Could someone help us out?
Paul Rodi
405, 346, 975 Alumni
President Emeritus of FIRST @ VCU
Coach 975, 1033, 1102, 1541 and whoever else
Unread 25-01-2011, 16:55
plnyyanks's Avatar
plnyyanks plnyyanks is online now
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Re: Rookie team: How do we set up our cRIO?
check out this document. it tells how to get started with imaging the cRIO. Is there anything else you need?
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 25-01-2011, 16:58
FRC #0975
We already have that, and it hasn't worked.
Is there a version of that for Windows 7?
Thanks anyway
Paul Rodi
Unread 25-01-2011, 17:02
plnyyanks's Avatar
AKA: Phil Lopreiato
Rookie Year: 2010
Thanks anyway
the cRIO imaging tool should work with Win 7 (it worked with my laptop running 7). To get to the network adapter configuration, click on start, type in "network and sharing center" and click on it, click "change adapter settings" on the left panel, right click on Local Area Connection and select properties, and set the static IP as per the document.
Unread 25-01-2011, 22:57
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What step doesn't work? What happens instead of what you expect? Be as specific as you can so we can give you useful advice on what to do next.
