Go to Post Someday, when I grow up, I want to join the GDC so I can make people go crazy, and then release hints that get people even crazier. - unionylibertad [more]
Unread 25-01-2011, 23:16
sjspry sjspry is offline
FRC #1984
Rookie Year: 2010
sjspry has a spectacular aura aboutsjspry has a spectacular aura aboutsjspry has a spectacular aura about
HS-322HD and Digital Sidecar PWM output
... does not seem to be working. The board is powered, also connected via the DB-37. The first of our two HS-322HDs is plugged into PWM port 1, and the jumper is in place. The + gets 6v, ground is 0v, but I don't know about the signal wire (I don't have an oscilloscope).
The motor jumps when first plugged in, but otherwise nothing seems to happen. When I don't set the "period multiplier" that PWM.java makes note of, the motor does not hum and/or heat up. So I'm assuming the signal is not working correctly, but perhaps it's something else.
As far as I can tell everything is plugged in correctly, and I'm using PWM.setRaw() and scrolling from 0-255 in increments of 5 with a delay of about half a second.
So, help?
Unread 26-01-2011, 01:26
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Re: HS-322HD and Digital Sidecar PWM output
So, help?
you have the correct module bay in the code? sidecar data cable good and plugged in? correct pwm port (in code and plugged in)
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 26-01-2011, 10:12
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
<snip>
So, help?
I am assuming the servo is not connected to anything (mechanically) and therefore not stalling.
Have you tried not setting the period and using set rather than set raw?
I have two servos running using the 'set', so there isn't anything broken there (library-wise) that I have seen, but I am not at the robot and can't look at the raw commands until later. If I haven't seen a resolution by then I'll try them this afternoon.
Unread 26-01-2011, 14:24
FRC #1984
Rookie Year: 2010
@ratdude747 I'll be checking the cables, but the sidecar should be fine. PWM and module are correct, as it just fails otherwise (module, anyway).
Yeah, it's not jamming. Will turn fine with the load I'm placing on it. I'll look later, but I didn't see anything other than "setRaw" and "setPosition".
EDIT: Thanks everyone for their help, it turns out the PWM was initializing correctly even though the module was not in the right slot (?!?!). I moved it and now it works
