Go to Post [In FIRST]...Arab and Israeli students speak on the same level, because they are alliance partners. - Tottanka [more]
Unread 26-01-2011, 17:08
LMD3130 LMD3130 is offline
Team Captain
AKA: Liam Driscoll
FRC #3130 (ERRORs)
Rookie Year: 2011
LMD3130 is an unknown quantity at this point
Blew The Tetrix Fuse???
We have blown are tetrix fuse, and are having trouble finding a replacement to use for are minibot please help!
Unread 26-01-2011, 17:10
klmx30302's Avatar
klmx30302 klmx30302 is offline
Is ready for MAYHEM In Merrimack!
AKA: Kevin McCarthy
FRC #0166 (Chop Shop)
Team Role: Mechanical
Rookie Year: 2010
klmx30302 is a jewel in the roughklmx30302 is a jewel in the roughklmx30302 is a jewel in the rough
Re: Blew The Tetrix Fuse???
Go to an automotive store and ask where the mini blade fuses are. you need a 20 amp one.
Unofficial Team 166 Videographer
Our team motto...
"THINK!, There must be a harder way!"
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Those types of fuses can generally be found in any auto parts store - try your local one!
Unread 26-01-2011, 17:12
Team Captain
AKA: Liam Driscoll
FRC #3130 (ERRORs)
Rookie Year: 2011
Thanks for the help.
Unread 26-01-2011, 17:13
Team Captain
AKA: Liam Driscoll
FRC #3130 (ERRORs)
Rookie Year: 2011
Unread 26-01-2011, 17:19
treffk's Avatar
treffk treffk is offline
botgirl
AKA: Kelli
FRC #1802 (Stealth)
treffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud oftreffk has much to be proud of
We did the same thing, luckily I had a box of assorted fuses in my car.
"If you always says yes, what are your yeses worth?"
Alumna of FRC Team 1802
Unread 26-01-2011, 17:22
klmx30302's Avatar
AKA: Kevin McCarthy
Rookie Year: 2010
Once we blew 3 (one of the students wired the motor positive to positive) we picked up an assorted box of 60.
And on a random side note TBA IS BACK UP!!!!!!
Our team motto...
Unread 26-01-2011, 21:40
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Update #5 allows (mercifully) the use of lower amperage fuses. So that assortment box may help you choose a lower amperage value. They are color coded. BTW the supplied 20a fuse is in place because for FTC robot use, the majority of robot power comes through that fuse, viz. two or more motors, several servos, controller boxes and sensors. So 20a makes more sense in that situation.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 30-01-2011, 16:37
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
We did some quick measurements of our minibot.
It draws about 3.6A climbing up the pole. A single stalled motor draws about 6A.
We're planning on using 5A fuses to prevent burning them out. (Unfortunately, ATM breakers aren't offered in values less than 10A)
-- Marshal Horn
