Go to Post Be kind to you mentors. They are exhausted and you need them. - MrJohnston [more]
  #16   Spotlight this post!
Unread 28-01-2011, 11:26
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Control of Decorations (Led displays)
Originally Posted by DavidGitz View Post
<R42> Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor, actuator or compressor).
Exception: Multiple low-load, pneumatic solenoid valves may be connected to a single relay module. This would allow one relay module to drive multiple pneumatic actions. No other electrical load can be connected to a relay module used in this manner.
From my understanding, a spike can control 2 circuits only if they are low-load, pneumatic solenoid valves. So you cannot control 2 different LED's (although I'm sure the current requirement is comparable).
If someone here disagrees, please let me know. Right now we have 3 relays for this purpose and I would not mind going down to 2!
David,
The multiple "low load" solenoid valves relate to the Crio solenoid/relay module. The Spike Relay module can control electrical loads up to 20 amps and can control multiple solenoids using the wiring suggested above.
See...http://content.vexrobotics.com/docs/...uide-sep05.pdf for a full description.
As long as you keep each LED string below 10 amps each and follow all other robot rules, you should have no problem.
Please be advised, bright LED strings, flashy decorations, or objects that mimic or emit light that can interfere with other robots using optical sensors may be viewed as objectionable under other FRC rules. Inspectors, refs or other officials may require you to disable them.
Al
WB9UVJ
www.wildstang.org
________________________
  #17   Spotlight this post!
Unread 28-01-2011, 11:42
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Al - Thanks for the clarification. I agree the current requirement will not even be close to exceeding the limitations of the spike relay, ours are about 30 mA max.
I may be "lawyering" these rules too much, but I am trying to make sure that I understand them fully. The document you specified was the one I was discussing as well. That document only specifies controlling 2 devices if they are solenoid valves. Obviously that document is not FIRST official but is just a reference.
So you are saying that the "single relay module" from the rules is not referring to the spike relay but is instead referencing the solenoid breakout, as seen here? I don't think this is true, and I think that I am misreading your post (although you did say "Crio solenoid/relay module").
So the question remains, are LED's (and their associated circuitry) considered an actuator? If so, then only one module may be controlled through a spike relay. If not, then there are no rule limitations (in this context, obviously practicality,safety and electrical limits apply) to how many be controlled by one relay.
I feel that I am beating this to death, and I will defer to your wisdom as an outstanding Robot Inspector.
  #18   Spotlight this post!
Unread 28-01-2011, 15:19
Unsung FIRST Hero
Rookie Year: 1996
David,
The interface you linked to is simply an add on module to the NI 9472 Crio module that came in your KOP. Each output can be accessed through the linked interface using PWM style connectors. The 9472 module has certain current limitations, 0.75 amps per output or 6 amps total for the module.
The Spike can handle significantly more current. However, I have yet to see a robot design that would require a large number of solenoids firing all at once from the same trigger signal. Since the Spike can handle currents up to 20 amps total (it is fused for 20 amps) it is commonly used for controlling higher current loads. Teams have used them to control decorations in the past. If you are proposing just one 30 ma LED, it is an overkill for the Spike I know. Unfortunately, there is no convenient way to power the LED through current hardware. I would ask the question of the Q&A as I don't remember this particular application has been approached before. Ask if you can use the solenoid module (9472) to drive LED loads and ask if you can use a relay or digital output of the digital sidecar to drive a custom circuit that would power the LED. (A simple transistor would suffice for the later.) I don't remember any rule off the top of my head that would prevent either, but will check later when I have more time.
BTW, the linked module is required to interface to the NI 9472 that came in KOP. There is an interface module included in your KOP.
Al
WB9UVJ
www.wildstang.org
Last edited by Al Skierkiewicz : 28-01-2011 at 17:33. Reason: Two solenoids is not correct.
  #19   Spotlight this post!
Unread 28-01-2011, 16:03
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by Al Skierkiewicz View Post
...ask if you can use a relay output of the digital sidecar to drive a custom circuit that would power the LED. (A simple transistor would suffice...)
If you're going to do a custom driver circuit anyway, don't bother with abusing the relay outputs. Just use a Digital I/O pin.
  #20   Spotlight this post!
Unread 28-01-2011, 16:21
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I'm not sure how something that doesn't move or cause motion could be considered an actuator.
  #21   Spotlight this post!
Unread 31-01-2011, 09:54
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
I just wish to clarify something,
If I use 5v lights, can I attach them directly to my DSC in the DIO side? That way I would just open and close to channel to turn on or off a light.
  #22   Spotlight this post!
Unread 31-01-2011, 11:31
Software Architect
The DIO pins are connected directly to the NI 9403 module, with a 10k pullup resistor to +5 volts. The module is capable of sourcing 2 milliamps per channel.
The Digital Sidecar 5v power supply is rated at 3A total. I don't know how much of that is available for use by external circuitry.
  #23   Spotlight this post!
Unread 31-01-2011, 13:00
Unsung FIRST Hero
Rookie Year: 1996
Alan and elbuo,
The 9403 module is speced at source and/or sink of 2 ma per output. Not enough to drive an LED.
Al
WB9UVJ
www.wildstang.org
