So I have the D-Link DAP-1522 set up to specifications in the KOP tutorial. The classmate is also configured to 10.16.33.5 (in local area connection though not sure if i need to change that to wireless connection). the classmate will also not find any wi-fi networks that our other laptops can find. however i do get connection when i plug an Ethernet cable into the classmate from the DAP-1522.
Re: Classmate not connecting wirelessly
on the back of the d-link make sure that it is AP mode
AP=Wireless and no Ethernet Auto=Whatever is connected first Bridge=Ethernet only |
It is on AP mode. i can get the DAP-1522 to connect with the other laptop that i am using, but i cannot deploy code to the cRIO.
did you reimage the robot?
also you need to make sure you have the WPA key and make sure the ip address of the clam is 10.xx.yy.6 where xx.yy is your team number |
Yes i have re-imaged the cRIO. i haven't been asked for the WPA key. and should the IP be changed in local or wireless access?
Did you follow the Rev A updated "How to Configure the Radio"? It was just posted.
You want your wireless connection to be 10.16.33.5, not the Local LAN. |
Yes I have fallowed that. I have also double checked it as well. I also just changed the IP of the classmate and it didn't do anything. I am thinking that it has something to do with how the classmate cannot even see out shops wireless network.
make sure that the wireless is enabled there should be a light on by the f keys. if its not you need to press the fn button and find the button to turn on the wireless
Yes the wireless is enabled. I even disabled it and enabled again, but it didn't change anything.
Now if for some reason when i tried to reconfigure the classmate with the update earlier it did not work. could that be the problem? |
#10
update?
#11
sorry. it was the 2011 Image for '10 classmate. one of my team members used the flashdrive on the wrong computer so i downloaded it from the FIRST website.
