Rookie Team Help- Robot Won't Move
Hello,
We just finished doing our wiring for the basic robot. We connected 2 jaguars to the 40 amp maxload and the other side to our two 12V DC motors running the chains connected to our wheels. When we put our code in and try to make it move using our joysticks, nothing happens. We are using the DefaultRobot java code. Any ideas why it won't move? Thanks, Alex |
Re: Rookie Team Help- Robot Won't Move
clear photos of the robot, electronics, all connections and the controls would help. Your issue could be hardware, electronics/connections, software, or some combination thereof.
Our jaguars are also flashing yellows lights
http://dl.dropbox.com/u/1281656/down...0126111911.jpg is a picture of our robot
Check to make sure the PWM wires are not plugged in backwards ie: the plug flipped 180deg. in the slot.
The PWM wires are plugged in correctly
Did you enable the control board when you pushed the joysticks forward?
Howe do we do that?
#10
Try using the Digital I/O module in slot 4 of the cRIO. I believe the default code uses that one.
#11
The digital module connecting the Digital sidecar is in the wrong slot.
It should be in slot 4. And you can get rid of the extra Digital module. The Analog module in slot 6 should come out. It, too, is in the wrong place, but you don't need it anyway. All you need for now is an Analog Module in slot 1 (you do have it there), and a digital module in slot 4. Last edited by Mark McLeod : 26-01-2011 at 20:51. |
#12
We are receiving the message "waiting to connect to OTA" in netbeans. It is attempting to connect through port 8001, and we assume this is correct. We can connect to it via FTP so we can assert that it is connected properly. The software has been updated on both the crio and the laptop. Why are we receiving this error message? We have successfully uploaded code at one point but this problem seems intermittent.
#13
Just as a side note, i'd think about moving that battery to the center for better weight distribution. Since you're using tank drive it's not a big deal, but it's usually something you want to keep in mind.
#14
Did you push the ON button?
#15
What do you mean by the ON button?
