Go to Post Tragedies happened. We've learned from them, as individuals, as teams, as a community. - Taylor [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 26-01-2011, 22:51
MattCarey3625's Avatar
MattCarey3625 MattCarey3625 is offline
#3625 Programming and Wiring Head
FRC #3625 (Some Assembly Required)
Rookie Year: 2011
MattCarey3625 is an unknown quantity at this point
Accelerometer Wiring
Hello, I know there are other posts about this same topic, however I have not found just what I need. We are trying to set up the accelerometer and I believe that it is supposed to be connected to the Digital I/O Sidebus correct? Old manuals call for placement in the analog but from looking at it unless we have a Female to Female PWM adapter I don't believe that it will connect to the driver station... I would be grateful if anyone can tell me how I should connect this. Thank you for any responses. ( I have already read the manuals available but ours has pins instead of small holes like in the manual... are the pins aupposed to be removed? They are soldered on I believe. )
matt@hp-mini-110$> sudo make robot
sudo pass for matt:
unable to make robot
