Go to Post User error is not the manufacturer's fault. - AdamHeard [more]
Unread 27-01-2011, 00:58
kaiapuni's Avatar
kaiapuni kaiapuni is offline
FRC #1378 (Green Label Zealots)
kaiapuni is an unknown quantity at this point
RS775 Motor and 256:1 Gearbox CAD files
Does anyone have or know where I can find a CADded Banebots RS775 motor and the 256:1 gearbox that goes with it? FIRST CAD Library only has the 256:1 for the 540s.
Alton's Rule:
If you can see that plan A won't work, don't do it, even if you don't have a plan B.
Unread 27-01-2011, 08:49
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: RS775 Motor and 256:1 Gearbox CAD files
I was able to find a P60 Model on this site: http://www.3dcontentcentral.com/(A(S...ne bots%20p60
It's not the correct thickness, so you'll need to reference the spec sheet on BB and re-model the ring gear housing to be the correct thickness for a 256:1.
For the 775, I just used an FP or something similar, but then again, my model didn't need to be perfect.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 27-01-2011, 12:54
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Can alternately grab the 775 model from the PTC KoP:
http://www.ptc.com/go/firstkop
Inventor can convert it, not sure about Solidworks.
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
