Go to Post Grease your gearboxes folks! Gears need grease, otherwise they kerplode. - s_forbes [more]
Unread 27-01-2011, 13:40
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
5th Gear
Does anybody have any info about the 2011 version of 5th gear? Is there an estimated date of release, or anything like that?
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 27-01-2011, 13:53
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 5th Gear
There's no official release date set, yet I do know the 5th Gear guys have been hard at work. If Blake doesn't get on here, I'll ping on him about it in the next day or so.
As a general rule of thumb, they don't like to release it until at least Week 4 of the build season. They don't get the rules ahead of time, so that basically gives them 4 weeks of time to develop the rulesets/models/etc into the sim. It also gives plenty of time for teams to come up with their own designs such that they shouldn't be influenced by the designs they see in the sim. Quite literally, they've had to code in 'magic' to the simulation robots to get their nuances to work properly in the PhysX engine. Unfortunately, that just doesn't translate into the real world. Go figure silly software guys get all the easy stuff.
Unread 31-01-2011, 15:44
MaxMax161's Avatar
Allegedly Useful
AKA: Max Llewellyn
Re: 5th Gear
Thanks a bunch, that info really helped.
Unread 02-02-2011, 08:00
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: 5th Gear
http://forums.usfirst.org/showthread.php?t=16670
I was up until 2:00 last night.
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 02-02-2011, 10:10
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
Re: 5th Gear
Thanks for all the hard work Blake. It's awesome you guys do this for us.
David
Unread 02-02-2011, 10:46
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: 5th Gear
David
Thank us when we finish, not before.
and... You can sleep when you are dead.
Blake
PS: You are welcome
Unread 03-02-2011, 09:26
MaxMax161's Avatar
Allegedly Useful
AKA: Max Llewellyn
Re: 5th Gear
Ignore this post until you're done. (I'll be to busy playing 5th gear then to post)
Thanks a ton!
Unread 03-02-2011, 14:23
Chris is me's Avatar
AKA: Pinecone
Re: 5th Gear
I'd like to thank Blake and the rest of the 5th Gear team for not releasing the software until after my first exams.
Unread 03-03-2011, 13:27
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: 5th Gear
Folks,
In addition to doing Chris a favor , we had a few thing to iron out; but...
I am going to stick my neck out and say that the initial release is literally hours away (should be less than [Edit] 48 [/Edit]). We have it "built", We are in the process of getting it onto/into a couple of download sites. Watch this thread for a link announcment.
If you are at the San Antonio or New Jersey Regionals LM folks are going to set up 5th Gear there.
I'm bracing my self for the inevitable flood of bug reports and requests for improvements - Go ahead and fire away once you have used it a little bit - First releases can always use improvement.
After a quick search in this thread, please post new bugs/requests here and David, Jim and I will get to them as soon as we can.
Blake
Unread 03-03-2011, 18:30
AKA: Pinecone
Re: 5th Gear
I see what you did there. Sneaky.
Unread 05-03-2011, 00:16
Deetman Deetman is online now
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
Re: 5th Gear
LM had our 5th Gear logomotion running all day Friday and will again be set up all day Saturday at the New Jersey regional. Stop by and be one of the first to try it out! (We also have some cool prizes too!) The San Antonio Regional should also have 5th Gear running Saturday.
As with any first release there are some issues to overcome but the 5th Gear team has done a great job getting this ready. Hopefully they'll be comfortable with a public release soon so more people can try it out. I know many people asked today if they could get Logomotion yet.
As a side note... Blake I sent an e-mail (work address) out about half an hour ago with some of the issues we encountered today. No show stoppers thankfully.
FIRST Mid-Atlantic Volunteer (2012-present)
Team 1014 Alumni (2004-2005)
Team 1712 Mentor (2011-2015)
Unread 06-03-2011, 11:52
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
Re: 5th Gear
Anyone have the link were I can get the 5th gear download? Sounds like it was working at the regionals.
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 06-03-2011, 14:15
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: 5th Gear
We have submitted requests to have it posted on both the WPI Think Tank and a public-facing Lockheed Martin site. We are waiting for the admins at both locations to approve the requests and thereby let the public (you) begin downloading it.
Unread 06-03-2011, 15:08
ghostmachine360's Avatar
ghostmachine360 ghostmachine360 is offline
Kyle J. Fender
AKA: Kyle J. Fender
FRC #1002 (CircuitRunners Robotics)
Rookie Year: 2007
ghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond reputeghostmachine360 has a reputation beyond repute
Re: 5th Gear
Mr. Ross, do you know if they're exhibiting the 5th Gear software at the Peachtree Regional again? We, over at CircuitRunners Robotics, have been the ones helping to set up and run the 5th Gear program for 2009 & 2010 at Peachtree with LM, but we haven't heard anything from LM, GeorgiaFIRST, or Jim Rundquist.
Member of the Rotten Fruit Alliance
2013, 2015, & 2016 Fantasy FIRST Elgin Clock Award Winners [RFA]
2015 & 2016 Fantasy FIRST Champions [RFA]
GeorgiaFIRST Advisory Board & District Planning Commitee Member
SPSU Class of 2016: Robotics Engineering Major
GeorgiaFIRST FRC/FTC Emcee, FTC Head Referee, & FRC Referee
2010 CMP FRC Dean's List & 2010 Peachtree DLA Finalist
  #15   Spotlight this post!
Unread 06-03-2011, 15:22
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Re: 5th Gear
With all the hectic fun of FRC build season, I can certainly understand if you haven't heard anything directly from Jim, but fear not; he has been writing code for the simulator this year (feel free to ask him why he either created or didn't already fix any bugs you find); and he has the Peachtree Regional in his sights.
So, "Yes", at Peachtree 5th Gear will be available for fun and for challenging other teams/mascots to contests in its vritual world.
Blake
PS: THANK YOU Circuit Runners for all of your help at the World Championships that were hosted in Atlanta. That will be a tough act to follow now that the Worlds will be in St Louis.
