Single acting cylinder with spring return
Can I use simple cylinder with spring return plunger with a 1 / 2 inch on the robot?
Re: Single acting cylinder with spring return
Which rule makes you think you cannot?
I relied on the checklist: "bimba.com" on the air, but the site only for double-acting cylinders, maybe I'm wrong, then I am in doubt. So, you can use or not?
I don't see why not.
I think YES, this is why:
If you are still not sure:I think the best chance for an OFFICIAL answer is, have the team leader go to FIRST Q&A Forum (on the FIRST web site), mention the specific cylinder part number, and ask. Then you know absolutely for sure, yes or no. ------- One alternative: Use a normal (double-acting) cylinder and use Latex Rubber Tubing to return the piston. Definitely OK. Last edited by DonRotolo : 29-01-2011 at 10:12. Reason: Added rule |
Gilmar,
The pneumatic rules have been relaxed this year to allow you to use devices as you describe. Any actuator may be used as long as it satisfies the 0.32 Cv, pressure ratings and is implemented safely. However, this might come into play. <R69> Compressed air for the pneumatic system on the ROBOT must be provided by one and only one compressor...Compressed air shall not come from any other source. |
